Go to Post The robots are the attracting force, the common interest that brings us all together - sanddrag [more]
Unread 02-03-2013, 05:50
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Re: Servo isn't working..!
Which example are you following?
here's a tutorial on the subject. try following the steps there and see if it helps...
http://frcmastery.com/wp-content/upl...ry_Step_3.html
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 02-03-2013, 09:15
rai337 rai337 is offline
FRC #1574 (Miscar1574)
rai337 is an unknown quantity at this point
it's exacly what we did actually.. we realy have no idea what's the problem..
Unread 02-03-2013, 09:33
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
OK so troubleshooting 101: isolate the problem.
Do you have an oscilloscope? (I seem to remember that your lab is well equipped). If so, you should try measuring the output of the signal pin (don't forget to connect the ground pin to ground!)
are you getting signal?
if you see a square wave signal, that's a good sign already. measure the frequency, it should be between 30-50 Hz. (the signal should have a period of ~20ms to ~33ms).
if you see all that, something is wrong with the servo.
if you don't see any signal -> probably software problem or wrong wiring (Digital side car working?)
if you see a wrong signal
(bad frequency or shape) -> probably software problem
-Paraphrasing JFK
Unread 02-03-2013, 11:18
We just solved the problem actually, from some reason the sidecar didn't work with the servo, so we're fine now. thanks anyway!
