Go to Post The real question is has anybody ever learned anything actionable from a game hint or red herring. - Joe Ross [more]
Unread 02-03-2013, 15:55
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Scoring 2013, I can do better than that!
A Frisbee has a a defined weight, so weighing them is one strategy for counting how many in a goal. A strain sensor with +/- 300 grams is a great choice, settlement time may be an issue.
But scoring does seem to be a problem. And since HindSight (tm) is always 100% there may be better ways.
So how would you have scored?
As a VEX and Arduino guy, I would done an pair of Sonar Senors. Mounted on each side of the top opening pointing down and across to cover the opening. Two sensors triggered = score.
But since the Sonar needs a pulse (so there is a read/write cycle), I would go with a short distance IR sensor, then I can get a constant read.
What would have been your plan?
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 02-03-2013, 15:58
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Scoring 2013, I can do better than that!
I would stick with weight, but use noise filtering and comparative score tests. Count score at the end of autonomous, then zero the scale.
I have a feeling frisbees are actually mostly the same weights, so I think weighing can be done.
All opinions are my own.
Unread 02-03-2013, 16:09
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
I would have planned for a streamlined human-based solution from the start. Something along the lines of how it was done in 2009, with handheld boxes with tactile buttons for real-time, and manual counting at the end of the match when the goals are emptied.
When was the last time we had an automated solution that reliably handled large quantities of game pieces being scored in parallel? (Answer: it's never.)
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 02-03-2013, 16:12
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Yeah, I was just going to point to 2006 as an example where the automated scoring system caused a ton of problems. It's hard to create a flawless system and this is the type of situation where it needs to be flawless. In 2006, I remember there were tons of issues with the scoring when the goals got clogged by the onslaught of balls and they had to implement a human-based system then.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
Unread 02-03-2013, 16:19
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
There were two issues in 2006, one was the goal getting clogged and needing the pokey stick to unjam, and the other was inaccurate sensors, especially in the low goal that tried to detect balls in parallel with a camera. They resorted to guys with counters watching each goal. The sensors had a tendency to miscount and the RTS couldn't be trusted at all.
In 2010 and 2012 they used low numbers of balls and single-file scoring to improve the system, although they still had their issues (including the infamous bounce-back DOGMA penalties in 2010).
2009 was human-counted from the start, but was horribly inaccurate because humans just couldn't estimate it as well as they needed to, or count fast enough for the large loads that got dumped in trailers.
Counting discs as they enter the goal is an issue because a) it's very hard to ensure you don't get a double-count and b) discs that don't stay in the goals aren't counted, and a pass-through sensor can't account for that.
At least this year they can recount the discs after the match...
Unread 02-03-2013, 16:21
AKA: Joel Gallant
That's a good point. Pro sports that have automated scoring only have one ball (eg. hockey, basketball, etc.)
Unread 02-03-2013, 16:30
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
I don't even think those sports have auto scoring. It sure take a long time from the score for my TV to update.
My Journey in FIRST:
Mentor/Coach/Engineer
2014-2017: Team 1076 - Pi Hi Samurai
____ 2014: Team 5220 - The Rockets
2009-2014: Team 313 - The Bionic Union/Bionic Zebras
Student
2006-2009: Team 313 - The Bionic Union
Unread 02-03-2013, 16:32
AKA: Joel Gallant
I know for a fact hockey and basketball use sensors and cameras to count.
Unread 02-03-2013, 16:34
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
They're not automated, though. If something is unsure to the referees in real-time, they go back and look at the tape. Why FIRST doesn't allow the same thing, who knows...
Does anyone else remember when TBA signatures actually worked?
Unread 02-03-2013, 16:38
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Similarly to 2011, I think they need to have humans manually putting the score on a touchscreen interface at opposite ends of the field. Yes, there could end up being errors, but I think it'd be a lot better than what we have now...
Unread 02-03-2013, 16:49
Patrick Flynn Patrick Flynn is offline
Patrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond repute
Hockey does not use an automated system. There is an official sitting behind the goal that turns on a light when he sees the puck go in. And the on ice official will make the call as he sees it.
Basketball scoring also isn't automated, how would a sensor know if it was a 3 or 2 point shot? the ref signals the number of points and a human increments the score.
The only sport that is close to automated, we could say is FIFA. This year they're going to is goal line technology that will alert the official's wrist watch when the ball crosses the line.
I'm not making any excuses for this years FIRST system but hardly any professorial sports are automated.
Unread 02-03-2013, 18:24
foote stepped in
AKA: E. Foote
FRC #0868
I'd funnel the frisbees into slots and trip a light beam (and let them drop into bins). Give a couple engineers a day and some materials and they could design a shape that prevents jams.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 02-03-2013, 18:37
archwaykitten archwaykitten is offline
AKA: John McBryan
FRC #1212 (Sentinels)
archwaykitten is an unknown quantity at this point
This is a robotics competition. Of course it should aspire to have autonomous scoring. They can't look at the engineering challenge of autonomous scoring and say "nah, that's too complicated. Let's just count things by hand". Not after what they asked us to do.
Unread 02-03-2013, 18:54
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
If manual counting works better I certainly hope they would.
FRC Team 4334
2012 - Archimedes Champions, IRI Champions
2013 - Western Canadian Regional Winner, Galileo Quarter-Finalilst
Unread 02-03-2013, 19:11
I started running through multiple ways to count the score in realtime automatically.
Short version, the current version (weight) is the simplest method for both transport and programming. However, as noted, there is a drawback of settle time and if there's a bit of a force applied.
Now, the 2 short-range sensors with both triggered = score is next simplest in execution, at least for transport. However, instead of both triggered = score, I would set it up to that 1 THEN 2 is a score. You can do that--in fact, it's how balls were counted in 2010 and 2012--and it will be pretty accurate. You can also set it to descore if 2 THEN 1 happens, to account for bounce-out (note that a trigger should be both on and off). But you do have to line the whole goal entrance to some extent.
The toughest method to implement would be an inline counter. Not because it's the hardest to program--it's easier than the above solution--but because you have to get incoming frisbees into line, when they're bouncing and sliding around in there. And that takes space and weight that may or may not be available. Slope (to get them to where you want them) can take a lot of material--and then you have to build in something to stop automode scoring at the end of automode, after a semi-reasonable delay to allow for the settling time.
