Thread Tools |
Rating:
Display Modes |
Re: Team 862 scouting database
This database worked really well for us at kettering. We got relevant data throughout the competition and were able to pick a winning alliance.
Can you upload it as an .xlsm file instead? The version you have up has no macros at all.
you might have to save it as a macro enable copy (save as-macro enabled excel)
When i tried uploading it CD wouldn't let me, xls could be uploaded |
also make sure you don't use any sorts in the raw data sheet because that will mess up the entire database. I will post updated versions with improvements
With our district win in kettering today we will definitely go to michigan state championships so i will post a 64 team database. |
That match was rigged... the score was like 330 to 90 but you still won!
Newest update for 2013 scouting database.
http://www.chiefdelphi.com/media/papers/2784 Works for up to 100 teams. Enjoy! Last edited by Dragonking : 07-03-2013 at 21:38. |
#7
nice looking database! i really like the format
my team did something similar to this though not as fancy here is the link to mine http://www.chiefdelphi.com/forums/sh...99#post1244299 |
#8
In case one of the macros wasn't working i just fixed the problem and re-updated it.
Any comments? |
#9
Team 862,
How do I enable the macros? I selected the text at the top when opening the spreadsheet but it still complains that the macros are not enabled? |
#10
Find the "save as" button
Find the "save as type" option and change it to "Excel Macro Enabled Worksheet" This should work. Also what excel version are you using (what year)? That might have some effect as well (this was made using 2007). |
#11
I like the database very much and 4183 will probably end up using this at the Phoenix Regional. However, I have a few questions:
What do you change or do if teams play fewer than 12 qualification matches at a regional? Is collected data intended to be entered in the "Raw Data" sheet? Is there anywhere to input notes on matches or data or media from pit scouting? |
#12
For the number of matches it will still work if there are less per team. Just ignore the message in the top left corner of raw data tab. Everything still works just as well. The empty spaces will be taken up with Missing! 1 etc. depending on the number of matches missing (or non existent). There may be an update for this by week 4 or 5.
The raw data is meant to be the input area. Just put in the data in the open spots underneath the appropriate header. You can sort by match or team depending on how you want to input the data. There is not a place to put pit scouting data or other such data. You could use the notes tab but that is meant for short notes on teams that stick out and for a separate pick list. Our team just keeps everything in paper form and takes it our when needed. This database is meant mainly for numbers. |
#13
New update.
http://www.chiefdelphi.com/media/papers/2784 Works no matter how many matches are played per team at a competition. Last edited by Dragonking : 16-03-2013 at 16:21. |
#14
This is just a suggestion:
I have an idea on an way to input match data. I made an outline of how the excel sheet could look like. Since I do not know how to make macros I did not put them on the buttons. (File is in the attachment) Description of how it could work: (I am not sure how to do it but, I think it would work best if the data could be collected from multiple devices and then it gets inserted into the appropriate locations on the master database) The user inserts the match number and then a drop-down list gives the user the choice of 1 of the 6 teams (this would give the macro a location to put the data). Then there could be a button the person presses after they put in the match and team numbers to confirm the team that they are scouting. After that it is pretty strait forward. The background button is shots missed and (for the climbing section) if they failed the climb (there can be another button if they didn't attempt the climb). Also you can add a button to time the robot's climb. If you want to be creative you can make buttons transparent and put them pictures above a picture of the pyramid/goal (I think it would only work with the pyramid though). |
#15
I'll mess around with in greater detail later, but it looks very slick and efficient. Thank you for sharing this.
