| Thread Tools |
Rating:
Display Modes |
#61
Re: What we learned from week 1
As an aside -- it looked like 326 has a big open groove in the middle. Is that intended for climbing? That's too bad they fell over in Q1; rotten way to lose. Last edited by Jaxom : 03-03-2013 at 15:41. |
#62
Yes these climbers and dumpers can be beaten with two solid shooters, but it all depends on the full alliance. |
#63
[quote=dtengineering;1242790]That is the single best camera angle that I've ever seen for an FRC video. It's better than the live camera operators at worlds... you can see EVERYTHING. It's just like being there, but with the added benefit of being able to rewind and rewatch parts that you missed.
Whoever mounted that camera... well done FRC 2337 uses a GoPro camera mounted next to the scorpion box on an umbrella pole. Clint Bolinger start doing this last year during the off season as a test bed. Nice work Clint as usual. Last edited by jmiller48167 : 03-03-2013 at 14:03. Reason: left off quote |
#64
Also, climbers (from what I've seen) tend to be less reliable. |
#65
WAY too much time was wasted lining up, even for some members of winning alliances. This might change in later weeks, but the teams that carried victory were the once that took no time to line up, and simply drove into the pyramid to line up for shooting, or into the alliance wall for loading.
Few teams can floor load well. 'HOT arms' dominated this weekend. Also, floor loading isn't necessary for victory (but it can speed up cycle times considerably.) There is no excuse for not 10 point hanging. Not hanging lost many teams many matches this weekend. Crazy high penalty points can all be avoided by smarter maneuverability. Avoid the enemy pyramid at all cost, either by ducking under it, or hugging the side of the wall. EDIT: And not defending a robot when they clearly can't or shouldn't be defended (loading zone!) Most Linear shooters are capable of full court scoring. Be prepared to defend it even if you haven't seen it from a robot earlier in the tournament. While short robots are nice for avoiding penalties, there should never be an alliance of three short robots. Edit: If there is, tape something tall to one of them ![]() Most importantly: Never leave a robot off your pick list because they are 'too good'. Sometimes even the best of robots can slip past the scouts of earlier seeds, and even be available as third robots. Edit: I'm talking about you; 910! EDIT: A top heavy robot is a fallen over robot. I won't feel bad for you when your robot falls over if you designed it to fall over, no offense intended. Also the impact of 'Robot in 3 Days' is very clear even at week one. A huge thanks to the guys who thought of it/put in the effort to actually do it! You're changing the face of FIRST, and making every match that much more exciting. Last edited by NotaJoke : 03-03-2013 at 14:26. |
#67
Especially if there's a "nuclear reactor" in your alliance partner's drivetrain. I did so enjoy 48's alliance with 1126 and 145.
![]() Last edited by Travis Hoffman : 03-03-2013 at 14:30. |
#68
I think we all learned from team 48 that if you're going to climb, you can't waste any time doing it.
#69
Look forward to seeing 48 at QCR and Crossroads later this season. All the best to 48, 1126 and 145. Not taking anything away from the Champions; it was a great finals. |
#70
So every robot has it place. We made a climber but do not tell others because they made a shooter it was easier to do. I thought it was easy to build a climber. Side note we did well do to our new PTO our students built this year. we only used 4 CIMs motors. Two on each PTO. When we switched over to climb we used all four CIMs. Plenty of power to climb fast. Our fastest time to the top was 25 seconds. |
#72
1. A lot of teams are using mechanum.
2. Not climbing can hurt you (already said by NotaJoke). 3. It's going to be hard to focus a camera through the netting, and not being able to get close to the field to take pictures will prove to be difficult. 4. Our center of gravity + the speed of our drivetrain = a lot of wheelies. 5. Watch out for flying frisbees. 6. Robots WILL get stuck in the pyramid (it took volunteers almost 5 minutes to get a robot down once). 7. Big sheets of lexan make for great noisemakers in the stands. |
#73
Our alliance in Palmetto hit 166 points without a single climb above 10 points. What I'm getting at is, climbing alone puts a very beatable ceiling on your score. |
#74
I do have to say, though, that 48's driver needs an award for the ballsiest defense I've ever seen in an FRC match ever--totally epic driving, that was! |
#75
Agreed, my post was more to tell them that the right alliance can still utilize a climbing dumper very effectively. It is by no means a locked win like some teams thought it would be. |
