Go to Post The GDC has spoken, we have listened and will follow their ruling. - ChuckDickerson [more]
Unread 03-03-2013, 16:05
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Re: Shooter consistency
A standard encoder might not be able to handle a wheel spinning that fast. What we used was a photoswitch from the 2011 KoP to count the spokes on the wheel.
Unread 03-03-2013, 16:29
How fast is "that fast"? The OP did not say what speed they are running their shooter at.
A "standard" US Digital E4P 250CPR encoder, if setup properly*, should be able to easily handle speeds up to 5000 rpm.
If the spokes are not wide enough, that detector will have difficulty keeping up at high speeds.
* connect only Channel A. Leave Channel B disconnected. Instantiate it as an up/down counter in the Counter class, and set it to count up only. Set the FPGA sample averaging ring buffer to 125. Use the getPeriod() method in the counter class, and compute rpm = 60/(250*period). See attachment.
Name:	5000rpm 250CPR 125N.png
Unread 03-03-2013, 20:05
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
What kind of motor, gearbox/drive train, shooter wheel, material on the "fixed" shoe, any other disc guides?
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Unread 03-03-2013, 20:12
iambujo iambujo is offline
FRC #2729 (Storm)
iambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to all
I can vouch for hall effect latch sensors on shooters and a well designed feedback/pid implementation. My team is able to pinpoint our desired speeds in about a second. We use a US1881 and custom pcb. Feedback from a sensor is key as others have stated, battery charge/quality can add a lot of variation otherwise.
Unread 03-03-2013, 20:19
Mongai's Avatar
Mongai Mongai is offline
Indian Guy
AKA: Alec
FRC #0935 (RaileRobotics)
Mongai is just really niceMongai is just really niceMongai is just really niceMongai is just really niceMongai is just really nice
If the spokes are not wide enough, that detector will have difficulty keeping up at high speeds.]
We had great luck putting a piece of reflective tape on our wheel and having the sensor count rotations of that instead.
Unread 03-03-2013, 20:51
Good to hear.
Would you mind answering a few questions to make this useful for other teams?
1) What optical sensor are you using?
2) What angle of arc is subtended by the tape at the radius where the sensing is taking place? In other words, what is the width of the tape (in the circumferencial direction) where it passes under the sensor, and how from the center of rotation is the sensing element located?
3) What wheel speeds were you measuring?
4) Were you indeed "having the sensor count rotations" or were you using the FPGA to measure the period? (That's an important distinction).
5) What speed control algorithm did you use?
Unread 03-03-2013, 21:03
Mongai's Avatar
Indian Guy
AKA: Alec
Good to hear.
I can definitely get an answer by tomorrow. I wasn't the one who worked with the optical sensor.
Unread 03-03-2013, 23:41
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Would voltage control mode on a CAN Jaguar be consistent enough to get away without a feedback loop? The way our shooter was done, I can't really see an easy way to add one. Transmission used belts, and the wheels we were given are Aluminum (so no magnetic sensor), and an encoder mount is impossible without redesigning the entire gearbox. We also used pneumatic tires with a custom machined rim (so no holes to track with an optical sensor). Unless we attached a magnet to the wheel and used a hall effect sensor below it... but that would destabilize the already fairly shaky wheel unless we used a *tiny* magnet.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 03-03-2013, 23:55
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Originally Posted by F22Rapture View Post
Would voltage control mode on a CAN Jaguar be consistent enough to get away without a feedback loop? The way our shooter was done, I can't really see an easy way to add one one. Transmission used belts, and the wheels we were given are Aluminum (so no magnetic sensor), and an encoder mount is impossible without redesigning the entire gearbox.
Betcha you could put a piece of reflective tape on your belt and use a IR proximity sensor on that. Don't get too attached on putting the sensor on some rotating thing, yeah?
As for the voltage control on a CAN Jaguar, that's better than nothing, not as good as actual feedback control. It will compensate somewhat for state of charge differences in your battery. It won't compensate for the spin down from firing a frisbee and it's going to deal poorly with rapid voltage changes from, say, your drivetrain or some other system making voltage fluctuate. Feedback is really the best way to go for getting fast, consistent shooting.
Paint the wheel black and then attach a piece of reflective tape and use an optical sensor.
Unread 04-03-2013, 00:06
F22Rapture's Avatar
AKA: Daniel A
Would the line tracking photoswitch from 2011 work, or is there another sensor that would be a better choice?
- Wernher von Braun
Unread 04-03-2013, 00:30
Yes, though it's a little slow. You typically need a pretty wide stripe to get it to work. Too narrow a stripe and it won't register. Practically speaking, you can make the stripe take up half of whatever surface you're sensing and it'll work fine.
Unread 04-03-2013, 00:52
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Be fair warned, our software folk had a ton of trouble with the battery voltage dropping too low when we used the KOP photogates, to then point where they gave bad data. We were running 2 CIMs on our shooter, and the voltage the sensors were seeing dropped from 13v to 10v when we spun them up to full speed.
-Plutarch
Unread 04-03-2013, 01:04
Read the last two paragraphs on page 2
Not sure if this rule exception is valid in 2013.
Unread 17-03-2013, 11:48
FRC #1899
I don't see anything in the rules about it, so I would say no. It wouldn't hurt to contact FIRST and see if they can add the exception back in.
