Re: Shooter consistency
A "standard" US Digital E4P 250CPR encoder, if setup properly*, should be able to easily handle speeds up to 5000 rpm. Quote:
* connect only Channel A. Leave Channel B disconnected. Instantiate it as an up/down counter in the Counter class, and set it to count up only. Set the FPGA sample averaging ring buffer to 125. Use the getPeriod() method in the counter class, and compute rpm = 60/(250*period). See attachment. Last edited by Ether : 03-03-2013 at 16:44. |
What kind of motor, gearbox/drive train, shooter wheel, material on the "fixed" shoe, any other disc guides?
I can vouch for hall effect latch sensors on shooters and a well designed feedback/pid implementation. My team is able to pinpoint our desired speeds in about a second. We use a US1881 and custom pcb. Feedback from a sensor is key as others have stated, battery charge/quality can add a lot of variation otherwise.
We had great luck putting a piece of reflective tape on our wheel and having the sensor count rotations of that instead.
Would you mind answering a few questions to make this useful for other teams? 1) What optical sensor are you using? 2) What angle of arc is subtended by the tape at the radius where the sensing is taking place? In other words, what is the width of the tape (in the circumferencial direction) where it passes under the sensor, and how from the center of rotation is the sensing element located? 3) What wheel speeds were you measuring? 4) Were you indeed "having the sensor count rotations" or were you using the FPGA to measure the period? (That's an important distinction). 5) What speed control algorithm did you use? |
Would voltage control mode on a CAN Jaguar be consistent enough to get away without a feedback loop? The way our shooter was done, I can't really see an easy way to add one. Transmission used belts, and the wheels we were given are Aluminum (so no magnetic sensor), and an encoder mount is impossible without redesigning the entire gearbox. We also used pneumatic tires with a custom machined rim (so no holes to track with an optical sensor). Unless we attached a magnet to the wheel and used a hall effect sensor below it... but that would destabilize the already fairly shaky wheel unless we used a *tiny* magnet.
#8
As for the voltage control on a CAN Jaguar, that's better than nothing, not as good as actual feedback control. It will compensate somewhat for state of charge differences in your battery. It won't compensate for the spin down from firing a frisbee and it's going to deal poorly with rapid voltage changes from, say, your drivetrain or some other system making voltage fluctuate. Feedback is really the best way to go for getting fast, consistent shooting. |
#9
Would the line tracking photoswitch from 2011 work, or is there another sensor that would be a better choice?
#11
Yes, though it's a little slow. You typically need a pretty wide stripe to get it to work. Too narrow a stripe and it won't register. Practically speaking, you can make the stripe take up half of whatever surface you're sensing and it'll work fine.
#12
Be fair warned, our software folk had a ton of trouble with the battery voltage dropping too low when we used the KOP photogates, to then point where they gave bad data. We were running 2 CIMs on our shooter, and the voltage the sensors were seeing dropped from 13v to 10v when we spun them up to full speed.
#13
Not sure if this rule exception is valid in 2013. Last edited by Ether : 04-03-2013 at 01:08. |
#14
It's not clear whether those numbers mean a) the pulse width must be 1 to 16ms in order to be reliably detected, or You need the stripe width to be 1/12 of a revolution at the point of sensing in order for it to be under the sensor for 1ms when the wheel is spinning at 5000 rpm. |
