Re: Quick help for a gear changing pneumatics system.
The minimum pneumatics system you need is shown in Figure 4-11:
![]() Plus one solenoid valve and a Spike relay to control the compressor. You have to have all of that, though not necessarily on you robot. You're allowed to leave the compressor, Spike, pressure switch, and relief valve off your robot to save weight. Though it has to be powered by your robot when it's recharging your tanks. On the other hand, are you SURE you want to do this? Swapping in gearboxes and adding an entire pneumatics system is not a trivial change to make. I'd put it at 2-3 hours for a really good team with a plan of attack. It will possibly take even longer if you've never used/mounted the ball shifters before and never worked with pneumatics before. You're likely going to eat up more of your thursday practice time making this change, so you might want to consider whether you're going to get enough benefit from this to make it worth the time, money, and effort. |
The relief valve must be attached directly to the compressor or attached by legal fittings connected to the compressor output port. If using an off-board compressor, an additional relief valve must be included in the high pressure side of the pneumatic circuit on the ROBOT. If you want to only store 60 psi (why?) you don't need one. And don't forget that if you move the compressor off-robot you have to have a manual vent valve both on & off the robot. Last edited by Jaxom : 03-03-2013 at 17:54. Reason: Add low-pressure store on robot. |
OP, here are two diagrams for your minimal required setup. Please note that I combined the compressor, pressure relief valve, and pressure switch in one block for simplicity; only the relief valve and compressor require a direct physical connection. You can plumb the ouput ports of one solenoid to both shifters in the same circuit (this saves a lot of plumbing and allows you to use one solenoid). Let me know if you have any additional questions. Again, this is only a guide and may contain unintentional simplifications. Always double check and refer to the rules outlined in 4.1.10 of the manual http://frc-manual.usfirst.org/viewItem/3#4 Last edited by protoserge : 04-03-2013 at 10:33. Reason: My reading comprehension is poor. Typical Monday. |
Do make sure you follow stinglikeabee's advice about the T-fitting if you're using a new compressor. You can't have any tubing between the compressor & the attached relief valve; this was a common problem in Hub City that caused 8 or 10 teams to re-work their pneumatics before getting their inspection sticker. |
