Go to Post Andy sent me this message last year: "you go, Jenny." I'm still waiting for him to say it's ok to stop. - RoboMom [more]
Unread 03-03-2013, 20:38
rhinobot's Avatar
rhinobot rhinobot is offline
I speak for myself, not my team
AKA: Rhiannon Brooks
FRC #5406 (Celt-X)
rhinobot is an unknown quantity at this point
Question CLIMBING RULES ?
OK so our team is wondering if after the match ends if the robot can the slide down i ask this because as soon as the robot is disabled it slides down because the motors are no longer powered PLZ SOMEONE HELP
My FIRST History
Team 4094 - Cyberwolves Rookie student/Captain, 2012
Team 2013 - Cybergnomes : Build Student, 2013-2014
Team 5406 - Celt-X : Mentor, 2015 - ?
Accomplishments
2014 (Team 2013): Western Canada Winners, Curie Semi-Finalists
2015 (Team 5406): Waterloo Finalists and Rookie All-star, Carson Division Quarter Finalists, Carson-Galileo Highest Rookie Seed
2016 (Team 5406): Greater Pittsburg Regional Winners, Curie Division Semi Finalists
Unread 03-03-2013, 20:40
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: CLIMBING RULES ?
The CLIMB is scored 5 seconds after the match or after all objects come to a rest, whichever is sooner.
I'd look into adding some sort of interlock on your robot, since if it can't stay up for 5 seconds then it won't count.
Unread 03-03-2013, 20:41
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Technically...that's not okay. So no, you robot can't slip back down, and it will be assessed from the lowest point of your robot.
Originally Posted by 3.1.5 Scoring
Points are awarded to ALLIANCES per the details below. Final scores will be assessed five (5) seconds after the ARENA timer displays zero (0) or when all elements come to rest, whichever event happens first.
Originally Posted by 3.1.5.2 CLIMB Points
Points are awarded for the highest Level achieved for every ALLIANCE ROBOT that CLIMBS its PYRAMID. The Level to which a ROBOT has CLIMBED is determined by the lowest point of the ROBOT (in relation to the FIELD) at the point in which final scores are assessed per Section 3.1.5.
Academic Student (Forever)
Andrew Lawrence
Posts: n/a
It's a little late to be asking this. Really. Go read the manual.
Here's the answer - Only look at it once you've read the rulebook:
Spoiler for Spoiler:
No, the robot needs to remain on the pyramid after the match until taken down by the team or field crew.
Unread 03-03-2013, 20:44
In short: Yes, it can slide down, but no climb points will be awarded due to the timing (the scores are assessed after 5 seconds or when everything stops moving--including your robot sliding down the pyramid).
There are some relatively simple ways to deal with this, including having a piston or servo put a pin into your climber's drivetrain to lock it.
Unread 03-03-2013, 20:47
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The rules (always a good place to start) says
"Points are awarded to ALLIANCES per the details below. Final scores will be assessed five (5) seconds after the ARENA timer displays zero (0) or when all elements come to rest, whichever event happens first. "
So if you robot should be scored where ever it is after 5 Sec after the end of the match. As a practical matter it might be when the Ref verifies your location which might be more than 5 sec.
Unread 03-03-2013, 23:48
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Suggestions:
Switch your motor controller to "brake mode"
Start working on a locking mechanism, stat... Maybe a pneumatic piston that slides into a hole on your gear, or something.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 03-03-2013, 23:52
Jibsy's Avatar
Jibsy Jibsy is offline
Mentor - 3756, 4525
AKA: Jared Baribeau
FRC #3756 (Ramferno)
Jibsy will become famous soon enoughJibsy will become famous soon enough
Originally Posted by F22Rapture View Post
Suggestions:
Brake mode only "brakes" when the motor is slowing down. It won't hold the position.
My suggestion would be a winch kind of thing. Like a volleyball crank, or maybe a rope cleat. Try googling those, see what you come up with.
Edit:
I also happen to have seen your climber. If you were to add another of a certain mechanism that is on the top to the bottom, it could just sit on that.
Unread 04-03-2013, 00:50
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
It will hold position, just potentially not very well.
Victors will break if there is no pwm signal and the break jumper is set.
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
Unread 04-03-2013, 01:29
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Brake mode on any of the legal controllers only shorts the motor leads together. The motor must spin to generate the electricity that is fed back into the motor which opposes the motor's rotation. So if the motor is not rotating there will be no braking action.
The amount of the braking action is in direct proportion to the speed of the motor. The higher the speed of the motor they greater the braking action. The lower the motor rpm the lower the braking action.
So with a high enough reduction setting it to brake mode will slow down the "slide" but not prevent it.
Unread 04-03-2013, 10:50
F22Rapture's Avatar
AKA: Daniel A
Which is true, but that was my point, because if their mechanism is slipping when the power is cut there's no need to make it hit the ground harder than it has to.
- Wernher von Braun
