Go to Post Inspectors are your friends and are there to make sure you are safe and legal to compete. - Al Skierkiewicz [more]
Unread 03-03-2013, 00:52
grimmcoder's Avatar
grimmcoder grimmcoder is offline
grimmcoder
AKA: Justin Grimm
FRC #2046 (Bear Metal)
grimmcoder is an unknown quantity at this point
Router not Working
Not quite sure why our router isn't working, we only supplied 52 volts to our brand new DAP-1522.
Unread 03-03-2013, 03:07
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Re: Router not Working
52 volts?!? Ya that would kill it
First thing to look at is the polarity correct coming off the voltage adapter into the router?
Does it work with the wall plug?
Try to reset it and update the firmware.
That said. we had our new router fail about an hour into our testing and drivers training.
Lucky we we able to put last years router on to keep going.
We had to bag the robot with the old router on it.
After working with Dlink tech support our router was deemed defective. Great thing is that it is under warranty, provided you can supply the proof of purchase. Have a call into FIRST parts to get this resovled but no reply yet. I got an automated reply that they are out of the office till mid week.
Our router has two led (power and bridge) that come on briefly blue then they all shut off and the power led turns solid red. We can run the firmware update but it doesn't help.
Good luck, worse case, you can swap it out at your regional spare parts table.
Not sure of any of this helps, but I feel your pain.....
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 03-03-2013, 10:33
Where did you get 52 volts? I know it didn't come in the Kit of Parts.
Unread 03-03-2013, 11:19
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
Firstly, 52 volts is clearly a typo. I can't even think of anything that uses or makes 52 volts. Did you mean 5 or 12? Were you supplying power through the WAGO connector on the PD board and the converter?
Secondly, What do you mean "not working"? No lights? No wireless? If it is no wireless, try resetting and reimaging the router.
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 03-03-2013, 21:58
grimmcoder's Avatar
grimmcoder
AKA: Justin Grimm
This was mostly a joke. Unfortunately, it isn't a typo. Apparently when you wire the power regulator backwards, it supplies 52 volts, instead of 5. We even used a Multi-meter to check it. We also fried our digital sidecar...
Woops.
Unread 03-03-2013, 22:33
mandrews281 mandrews281 is offline
FRC #0281
mandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to behold
Woops.
Last year we fried our camera when the connector was wired up backwards and (tried) to learn our lesson: multi-meter (volts or ohms as appropriate) every connection before making it the first time.
Michael Andrews
Team #281 Programming Mentor
Unread 04-03-2013, 03:15
xisybyl xisybyl is offline
FRC #3648
xisybyl is an unknown quantity at this point
Re proof of purchase for defective router:
After two long phone sessions with tech support we called DLink again but this time Customer Service (NOT tech support). Anyway after yet another session w/ TS (and explaining who we are, what we are about, and why we don't have a PofP) Customer Service graciously agreed to replace our router without PofP as a "one time courtesy replacement".
So, if you are willing to spend yet more time on the phone you may be able to obtain a replacement from DLink. Be sure they know you MUST HAVE rev. B1. Also bear in mind that time may be tight. Last time I looked Andymark had Rev. B1 in stock (watch out for the Rev A on their website).
Good luck.
Unread 04-03-2013, 07:56
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Two related comments on the D-Link router.
It's really hard to shop around to buy one because most sites that probably have the current model still haven't updated the photo on their web sites. The only way we could be sure to get the V2 model was to buy through Andy Mark.
The DAP-1522 (either version) will survive accidental application of 12v, as long as the polarity is correct. Unfortunately, 52v was pushing your luck!
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 04-03-2013, 08:56
arun4444 arun4444 is offline
FRC #3760
arun4444 has a little shameless behaviour in the past
http://www.andymark.com/DAP-1522-REV-B-p/am-0839.htm
overnight?
Unread 04-03-2013, 13:00
Last year, FIRST posted the proof of purchase so that teams could RMA the radios. I haven't seen it this year, but I assume it's something that the FIRST KOP team could give to you.
Unread 04-03-2013, 17:24
What does "backwards" mean here? Did you connect the power input wires to the PDB's dedicated 12-volt output with the wrong polarity? Or did you connect 12 volts to the output wires and plug the input wires into the router? Knowing a little about how the power converter works, I'm having a hard time imagining how any combination of wiring errors could result in 52 volts on it somewhere.
And how does the Digital Sidecar enter into this? It shouldn't have a connection to the power converter at all.
Unread 04-03-2013, 23:53
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
If you connect the 12 volt line to the output the input will put out ~50 volts.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 08-03-2013, 23:03
FRC #3760
lol, how sure are you about a reading from a $3 multimeter?
