Go to Post Once this competition is over, we should donate all of these Poof balls to daycares, elementary schools, neighbors; all the little kids. It would make us look good like, "Here's our Toys for Toddlers gift from us upstanding citizens. And we build robots." - atomikitten [more]
Unread 23-01-2003, 23:05
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
Sideways mounting
What do you think of mounting the victors sideways to save space? We are buildin an under 14" robot, so space is at a premium, and some recent calculations show that some space can be saved by having victors mounted sideways. Does anyone have ny experiences with doing this before?
SVR Imagery Award
SVR Semifinalists with 473 and 687
RIP Andrew Dang
3/22/2004
Unread 23-01-2003, 23:18
Curtis Williams Curtis Williams is offline
#0588 (Team 588)
Curtis Williams is on a distinguished road
Send a message via ICQ to Curtis Williams Send a message via AIM to Curtis Williams Send a message via MSN to Curtis Williams Send a message via Yahoo to Curtis Williams
For the last two years my team has mounted victors sideways using velcro with no problems. I dont see any problem with mounting them upside down either. Just be sure the PWM cable can't slip out.
Unread 23-01-2003, 23:55
PyroPhin's Avatar
PyroPhin PyroPhin is offline
None #0263
PyroPhin is on a distinguished road
Victors are solid state components.. they dont care where or in what direction there mounted in.
it shouldnt be that much of a problem ^.^
~Pyro
Squee!
Team 263, Aftershock:
Alumni, guy who comes back and fixes Krass's mistakes
Unread 24-01-2003, 00:23
srjjs's Avatar
AKA: Larry Wang
I know that they will still work, I was wondering more about ease of access, especially when the vertical panels are attched at the bottom to another flat panel, and about how much space it frees up.
SVR Imagery Award
RIP Andrew Dang
3/22/2004
Unread 24-01-2003, 00:34
Happy Birthday! rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Simply turning a speed controller upside-down won't save you any space; it's volume is the same regardless of orientation. It will let you put it in a place that would otherwise be left as dead space, however. Whether or not this is benneficial depends on your particular robot and needs to be weighed carefeully against the disadvantages. These include being harder to access, having the PWM cable fall out more likely, and the inability to see the little LED for diagnostics.
Last year, we were so pressed for space we had relays and speed controllers mounted in every imaginable position and wire running all over the place. Whatever you do, plan it in advance and allocate enough space for the wires to attach to the sides.
Unread 24-01-2003, 00:38
Umm Errr...
If u put it upside down, while it is highly unlikely that the PWM cables would come unplugged i would still strungly recomend that you hot glue them etc un place. nothing permanent but something that will hold. maybie some kind of loctite product.
1139 Alumni
Unread 24-01-2003, 01:15
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Re: Sideways mounting
No you can't, because the magic black smoke will float to one side of the speed controller, and it won't work properly. The magic black smoke will only operate when positioned upright.
Just kidding... actually, last year we mounted the speed controllers on the top of a chunk of polycarb. Then we mounted the relays on the bottom. Mount them however you like.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 24-01-2003, 07:41
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
You won't quite "save space" as rbayer also said. By changing the orientation you may create more "open space" at certain points. There won't be any problems with having speed controllers at an angle, just make sure you allow airflow or the magic smoke may show up.. or maybe won't show up (which can be worse because you can't smell which one is frying)
Unread 24-01-2003, 10:27
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
if your moutning them in a tight space then u might want to consider using the muffin fans.
We are running into a similar problem it seems and we have a small 14x10X6 inch box we are mounting the entire electrical systems in and a 7.25X10x10 inch box to mount all the pneumatics in...
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 24-01-2003, 14:34
srjjs,
We have mounted them sideways whenever the layout dictated it. We have used peel and stick velcro to mount them as well. The PWM cable fall out is a real problem but that can be overcome in a variety of ways but most effective is a simple ty wrap of the PWM cable to the power supply wires near the controller. In the event of a failure this gives you the best repair time. Can't wait to see you short bot.
Unread 24-01-2003, 16:40
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Just make sure your light is mounted upright!!
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 25-01-2003, 19:38
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
- Katie
Is the light mounting a requirement, or just a suggestion? I know that with the the velcro lights we had the last two years, it was a good idea, but these new screw-on (at least I think they're screw-on) lights could conceivably go sideways. Is it a rule, though?
EDIT: Stupid me, I checked the rule book a minute later, and found my answer. It is required to be upright, per rule M8.
Jeff Waegelin
Unread 25-01-2003, 19:40
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Yes it is a rule, when i find it i'll edit it back in.
*edit* he fixed it before I found it *edit*
Unread 25-01-2003, 20:31
BBFIRSTCHICK's Avatar
BBFIRSTCHICK BBFIRSTCHICK is offline
Someone find me a FIRST team
AKA: Adriana
#1077 (was: All Stars)
BBFIRSTCHICK is on a distinguished road
Send a message via AIM to BBFIRSTCHICK
Last year we did that.....We mounted the Victors right on top of a lexan sheet that was mounted on to our transmissions. The only thing I can think of, is if it is going to be really cluttered in the area you are going to put the Vic's in you might want to put a fan. That's what we did. We had no problems with them whatsoever
Team 59 "Ramtech": 2000-2002
Nationals 2001: Galileo Division Champions, National Semi-Finalist
Team 1077 "All Stars": 2002-????
Semi-Finalist, Peachtree Regional 2003 (507 and 356 Rock!)
Fischer Price mounting screw ateene Motors 1 09-02-2003 21:00
drill motor mounting whynot Technical Discussion 3 03-02-2003 08:24
new bosch pinion and mounting ajlapp Motors 1 08-01-2003 17:16
Wheel mounting Moshingkow Technical Discussion 15 09-10-2002 19:25
Mounting the rotation light MrB Technical Discussion 3 18-02-2002 17:36
