Re: OPR after Week One Events
I forget, what's the difference between OPR and CCWM now?
1.) Pyramid range shooters lead AUTO
2.) Full court shooters lead TELEOP 3.) Climbers lead CLIMB points No surprises here. Though I would expect this to change in the coming weeks. As defense adapts to these playstyles, I think pyramid range shooters teleop points will only climb (no pun intended) and as the powerhouses unveil, jacks of all trades will start to dominate climbing. Last edited by Grim Tuesday : 04-03-2013 at 18:18. |
Well you also won your event so I guess that helps
![]() Calculated Contribution to the Winning Margin (if you have the file look at cell F31 on the query sheet) |
- Sunny G. |
Wow. I cannot believe what I'm seeing right now. This is so cool! /dork Thanks, Ed and Akash. |
Quick correction: Ed and Aaron* My post was quoting Aaron. 1640 looked solid at Hatboro, I'm happy a couple of the teams on Aaron's lists are from MAR. |
#7
Except 610 (at least from the videos I saw) and 1986 are both pyramid shooters, and are numbers 2 & 3 on the teleop list.
#8
http://www.youtube.com/watch?v=uNDNXdb0Vy8 I agree with what you're getting at though, you don't have to be a full court shooter to put up some of the best teleop numbers, 1986 being a prime example of this. |
#9
Did they start getting blocked, and just do pyramid during the finals? Or did I see just the aberrations? |
#10
From my interpretation if they thought they could shoot without being impeded they would do full court shots. Otherwise, they will do pyramid shots. Their full court shooter is deadly accurate when they do run it though.
#11
We only demonstrated our full court shots during 2 matches, where we were fairly certain that no defence would be played on us. However, when defence was played, it turned out that we gain more points through running cycles than with the long bombs. Thanks for the kind words!! -Austin |
#12
Agreed, some of the best pyramid shooters can lead teleop but 3173 (exclusive) and 610 (optional) were both full court shooters as far as I know. Like I said, I expect this to change the more prevelant defense gets. 3003 absolutely shut down 3173 in the seminfials at FLR with their arm and anyone tall could do that. However, qualifications are luck of the draw, so expect full court shooters to be seeding high as they won't always have a competent defender against them.
#13
Hearing those shots hit right above the driver station over and over again before they ever touch the sticks has to leave quite an impression with the opposite alliance. |
#14
Gotta love them Martians... |
