#196
Re: What we learned from week 1
What we noticed is that robots lining up for a shot while touching the pyramid were mugged by aggressive defense without a penalty being called in several instances. Those who were attempting to climb were given much greater protection. Hopefully in week 2 those calls will be more consistent. We also noticed that if a defender played along the field wall and hit opponents into the pyramid as they went to the feeder station it was ruled a G-18 and the defender was given a technical. The loading robot appeared to have no responsibility in avoiding the pyramid in this situation. Defenders learned to play from the pyramid side and force the loading robots into the wall instead. |
#197
Same...I think that selfish players that hogged frisbees really would've become a problem
#198
If that's the case, how could you ever get a clear shot? Sounds like missed calls and as you mentioned, hope those calls become more consistent. |
#199
The scenario described are not so blatant.
From what I saw were the following; Say team XXXX tried to line up at the back of the pyramid using uprights or something, then defenders usually left these robots alone. I never saw an instance of contact in this scenario, but I'm sure that had it occurred, it would've been called without hesitation. Say team XXXX is trying to line up in the corner or even in the front of the pyramid (at this position, taller robots can really get in your game), then there is guarantee of a call. I suppose there's a little room to tussle but when illegal contact is made, it wasn't called very often, if at all. - Sunny G. |
#200
)On a separate note... We saw 60" defenders become effective at blocking full court shooters, but we didn't see many attempt to block pyramid shooters. If the refs continue to have difficulty telling when someone is touching the pyramid we might see the defense become more bold. *Interesting clip here: http://www.youtube.com/watch?v=spyRub7z1Bw *We had a bad battery in this match so you will see us escaping the defensive pressure in low gear instead of our normal zippy selves. |
#201
I haven't had time to read this whole string, but I'll say that I learned that even teams that say they can climb for 30 (or 50) didn't at the Hub City and shooting frisbees four at a time is the best skill.
But like others here have said, even rookie teams were competitive and a ten-point hang is completely worth it. Many videos of Hub City (for team 1108) at my youtube site. [url="https://www.youtube.com/user/hrench"] |
#203
That was a huge hit if I've ever seen one. If you look at the picture they show a little later, 16's bumper comes up and hits them inside their frame perimeter. Nothing against 16 but if I was a ref and saw that I feel like I would call something.
#204
![]() It was round 84 of the qualifications (great match, btw), and it was somewhere around the 1:30 mark. We were lined up against the back of the pyramid shooting when one of your alliance partners came up and gave us a nice firm tap in our rear end. I thought it was crystal clear that it was a foul - not sure how they missed it. If you have video of that match, check it out and see if you agree. We put up 54 points that round on 15-15 shooting, so we were majorly psyched in spite of the loss. It was a great tournament for you guys - congrats on achieving the #1 rank and best of luck at Peachtree. I hope you guys make it to St Louis. |
#205
There is no foul rule that applies to this situation.
#206
3.2.6.2 G29
Deliberate or damaging contact with an opponent ROBOT on or inside its FRAME PERIMETER is not allowed. G29 does apply, depending on the severity of the contact. Edit: The blue box appears to limit the impact of this rule to contact by appendages. Contact by bumpers may be a good candidate for a Q&A question. Last edited by smistthegreat : 05-03-2013 at 11:22. |
#207
My comment was not that G29 did not exist, only that it did not apply to this situation. A robot tipped while being pushed and their bumpers overlapped momentarily. Hardly deliberate, damaging contact.
#209
Read your own quote:
High speed accidental collisions may occur during the MATCH and are expected. ROBOTS extend elements outside of the FRAME PERIMETER at their own risk; no penalties will be assigned for contact between two such extended elements. 16 had no such extended element. Their bumpers overlapped. It happens. |
#210
