Go to Post The pie is as large as you make it. - boomergeek [more]
Unread 05-03-2013, 10:45
pntbll1313's Avatar
pntbll1313 pntbll1313 is offline
2052 Coach, Build/Electrical Mentor
AKA: Pete
FRC #2052 (KnightKrawler)
pntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud of
Robot starting Config, 84 inches?
Can a robot start at 84 inches? I know that they cannot go to the other side of the field but assuming they are this tall for defense they may stay by the opponent’s loading station anyway. I'm thinking for teams that may be a 3rd round pick and slap a pvc pipe that cannot be retracted to their bot.
3.3.5 ROBOT Actions
G22 ROBOT height (as defined in relation to the ROBOT) must be restricted as follows during the MATCH:
A. If in contact with the carpet in its AUTO ZONE and/or its PYRAMID, ≤ 84 in.
B. Otherwise, ≤ 60 in.
R4 In the STARTING CONFIGURATION, no part of the ROBOT may extend outside the vertical projection of the FRAME PERIMETER, with the exception of minor protrusions such as bolt heads, fastener ends, rivets, etc.
As I read those rules if the robot is in the autozone to start (obviously it is) and it does not extend outside the vertical projection (so 84" straight up would be allowed) then this robot would not be allowed to cross the auto line but is legal.
2016 (mentor/drive-coach)
Quarter-Finalist-Einstein, Winner-Carson Division Champs, Winner-10K Lakes, Chairman's Award-10K Lakes, Finalists-Lake Superior,
Winner-MSHSL Robotics Competition
2015 (mentor/drive-coach)
Finalists-10K Lakes, Finalists-Lake Superior, Finalist-MSHL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2014 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior Winner-MSHSL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2013 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior, Winner-MSHSL Robotics Competition, Quarter-Finalist-Newton Division Champs
2012 (mentor/drive-coach)
Finalists-Lake Superior, Semi-Finalist-MSHSL State Championship, Semi-Finalists at 10,000 Lakes
2008-2011 (college mentor)
2007 (driver)
Quarter Finalist-Milwaukee
Unread 05-03-2013, 10:47
Chris is me's Avatar
AKA: Pinecone
Re: Robot starting Config, 84 inches?
The robot must start in starting configuration, not in match configuration. It must start at 60 inches.
Unread 05-03-2013, 10:48
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I was under the same impression... however, can you provide the rule that states the STARTING CONFIGURATION is limited to 60" in height?
2016: Lake Superior WFFA
Unread 05-03-2013, 10:50
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Chris, would you mind citing a rule? I went back to the rules to refute this claim myself and actually found that OP may have the correct interpretation. Hadn't caught that...and I thought reading the rules 7 times was sufficient!
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 05-03-2013, 10:53
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
This is all I can find in the manual.
G22
Otherwise, ≤ 60 in.
Violation: FOUL. If continuous or repeated violations, TECHNICAL FOUL.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 05-03-2013, 10:56
hehe, I did the same thing. Searched the rule book for "STARTING CONFIGURATION" and "60", couldn't come up with anything stating robots needed to be under 60" in their starting configuration.
Unread 05-03-2013, 11:00
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
This came up in the discussion of my rules quiz. You can technically be 84" tall at the start, but you may never leave the C shaped area between your goals and the back of the pyramid (side furthest from the goals of the same color).
A hint is the blue box for R03, which reminds you to consider G22. If you consider it and are still 84" at start, that is your decision.
Unread 05-03-2013, 11:07
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
The STARTING CONFIGURATION is defined by R04 and in the definitions section. There is no reference to height, only that all parts of the robot must be within the frame perimeter. You may start the match up to the same 84" limit that appiles otherwise. We had occasion to add a fixed, 83" shot blocker to one of our alliance partners.
Unread 05-03-2013, 11:10
AKA: Carl Springli
Starting at or below 84" deemed legal at Hub City:
http://www.chiefdelphi.com/forums/sh...8&postcount=61
Unread 05-03-2013, 11:46
AKA: Pinecone
Man, I've read that manual seven times, and I could have sworn you had to start under 60! Thanks for calling me out on this one, glad we got to the right answer.
Unread 05-03-2013, 13:06
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I didn't interpret it that way until I saw the HolyCows' robot just after Stop Build day. It's easy to miss. (Not that their robot is > 60" pre-match ... just that their design inspired me to figure out what the starting limit is).
GitHub
