Go to Post We try to limit ourselves only by physics. As the first person on the planet to communicate over a quantum encrypted AOL instant messenger session, I try to ignore those limits as well. - EricVanWyk [more]
Unread 03-05-2013, 04:21 PM
JefferMC JefferMC is offline
AKA: Jeff Corbett
FRC #1319 (Flash)
JefferMC will become famous soon enough
Re: SmartDashboard Poll
I refer both to the Java application that runs on the Control Computer and to the class of the same name that communicates with it via NetworkTables. That they use the same name instantly draws the connection between them in ones mind, and I can't believe that wasn't intentional.
We disconnected the camera (configured at a 1.7 Mbps consuming 320x240x30x30%compression) and quit running the Java application as I was advised by the FIRST personnel. This resolved our issues for the remaining matches.
I specifically asked the FIRST representative if I needed to remove the SmartDashboard class calls in my code and the answer was that to stop running the Java application was sufficient. Again, this representative was explicit in making sure I was talking about Brad Miller's Dashboard vs. any other Dashboard application.
Okay, yeah, maybe I should have posted this in the common Programming forum. I sorta forgot that this feature was common with our Java friends.
