Go to Post The Lord of the Bots.... - Bob Steele [more]
Unread 05-03-2013, 16:38
EricDrost's Avatar
EricDrost EricDrost is offline
Eleven to MidKnight
FRC #1923 (The MidKnight Inventors)
EricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond repute
Re: Frictionless tape.
You're looking for Teflon Tape.
Edit: Beat me to it.
MORT Team 11: 2008 - 2015
MKI Team 1923: 2015 - Present
Unread 05-03-2013, 16:41
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Is there a better name for Teflon Tape that's unambiguous to the pipe Teflon tape that has no sticky backing?
GitHub
Unread 05-03-2013, 16:46
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Jesse, I believe "Teflon Surfaced Tape" or something similar would suffice. We initially went with that for our mechanism, but considering how much we did to the darn thing we decided on raised plastic strips that the disks slide on. Also, insert snarky comment about "friction-less tape" here.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Bob Steele's Avatar
AKA: Bob Steele
Ultra-Slippery Tape Made with TeflonŽ PTFE
http://www.mcmaster.com/#surface-pro...n-tape/=lr19xv
or try a UHMW tape...
http://www.mcmaster.com/#surface-pro...n-tape/=lr1agr
some are sticky back... others you apply with an adhesive...
Unread 05-03-2013, 18:03
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
This is what we picked up for a similar purpose:
http://www.amazon.com/CS-Hyde-Polyet...ords=UHMW+tape
UHMW tape with adhesive back - only .020" thick, easy to apply, and offers a slippery surface. Not sure if the teflon tape that Bob mentioned would be more slippery, but the price was hard to beat for a 18 yard roll.
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
Unread 05-03-2013, 18:28
Andy A. Andy A. is offline
Getting old
FRC #0095
UHMW Polyethylene tape is possibly a better choice then PTFE for a lot of FIRST applications. It's more abrasion resistant and generally tougher. It's not quite as slick, but it'll retain it's properties under harsh or less then ideal conditions. It's also pretty cheap.
Mcmaster has a wide variety of it. I'm a fan of the 3M VHB adhesive backed stuff. They aren't kidding when they call it Very High Bond; it sticks to everything and stays there.
Unread 05-03-2013, 21:17
BradleyView BradleyView is offline
no team (TBD)
BradleyView has a spectacular aura aboutBradleyView has a spectacular aura aboutBradleyView has a spectacular aura about
Send a message via AIM to BradleyView
This is actually what I do for a living. I definitely agree UHMW is probably your best tape for this particular application- it will not wear as easily, not quite as low coefficient of friction but should be good enough, and it will be either an acrylic or rubber adhesive which is better in case you have to take it off. PTFE tapes are commonly silicone since they are used for their stability at relatively high temps, although they do come in acrylic or rubber.Silicone would make it a pain if you did have to take it off and try to stick anything else where you had the tape previously. UHMW can be milky white to clear.
Mentor/Drive Coach-Team 2791- Shaker Robotics 2011-2014
Mentor-Team 229-Division by Zero 2008-2011
Clarkson University Class of 2011
Unread 05-03-2013, 21:33
pilum40 pilum40 is offline
Steve Miller-Coach-Team 3355
AKA: Steve Miller
FRC #3355 (Bigg Redd)
pilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud of
We use 2" Teflon tape. Bought it by the roll via McMaster-Carr. This is one of the best things I've learned as a coach/mentor this year....I had no idea anything like McMaster-Carr existed. Great find! Thanking our mechanical engineer mentor from Lockheed-Martin!
Unread 06-03-2013, 10:34
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
We used Lemon Pledge. Seriously.
And the robot smells nice.
Unread 06-03-2013, 10:41
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
This! Spray it on the floor next time your moving a heavy machine. Glides like air hockey.
