Go to Post Mentor: How is that held in place? CAD Lead: Go to the hardware store and buy a bag of constraints and put the constraints on the robot. - Kenyow [more]
Unread 04-03-2013, 15:30
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Sensor "de-noising"
Originally Posted by mrklempae View Post
This year we're using a moving average to filter out noise from our sensors. It's about seven lines of code total, and works by feeding a stream of data into an array and calculating the average continuously. It works really well for rangefinders, but I'm sure it's applicable to almost anything. All you need to do to adjust the sensitivity is change the sample size.
Applicable to anything except a digital signal. Unless 2/3rds on has some sort of meaning I'm unaware of.
Unread 05-03-2013, 13:26
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
While Kevin's approach is far more elegant, this might work for you in a pinch:
/* some set-up */
#include <stdio.h>
#define true 1
#define false !true
typedef char boolean;
/* a program to run the stuff */
int main (void)
static int array[5] = {0,0,0,0,0};
static int counter = 0;
boolean persistence;
boolean digitalInput;
int i;
/* run the persistance checker in a loop */
 for (i=0; i<10; i++)
   /* put in some false then put in some true */
  if(i>4)
     digitalInput = true;
  else
     digitalInput = false;
  /* check on the input and fill the
   * persistence array with the result
  if( digitalInput)
    array[counter] = 1;
  else
    array[counter] = 0;
  /* keep tabs on the array index */
  counter++;
  if(counter > 4)
        counter = 0;
/* now AND the entire array and show the result */
  persistence = array[0] && array[1] && array[2] && array[3] && array[4];
  printf(" perist = %d \n",persistence);
When the array fills and remains filled, you get true, otherwise it's false
...ugly but it could work
Eric
Don't PANIC!
S. P. A. M.
Unread 05-03-2013, 17:08
Here's a simple IIR filter which does essentially the same thing with 2 lines of code, no loops, and no conditional logic:
ave = 0.5*(input+ave);
output = truncate(ave+0.03);
It does use floating point (for ave), but the cRIO has an FPU.
input and output are 0 or 1.
Unread 06-03-2013, 02:24
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Last year we created a class to handle averaging out our noise. we were using this for sensors that gave us analog data, but you could send in 1.0 and 0.0 on the output side for a digital signal.
What ended up being nice about this class last year was that we could very easily change how many samples were being included in the average. As we started to speed things up throughout the season, we needed the average to be more responsive (fewer samples)
Here's the Java code: https://gist.github.com/jcorcoran/5097376
http://team2168.org
Unread 06-03-2013, 08:47
The 0.03 number can be adjusted to accomplish the same thing.
Unread 06-03-2013, 09:01
It's been a while since I've done IIR filters and such, so my math on them is rusty. Is that actually exactly equivalent to checking than the signal has been 1 for the last X ms? It would seem that it would tolerate some blips low. And it definitely switches 1->0 quicker than 0->1.
Mind you, it's probably a perfectly cromulent and simple solution to the OP's actual problem, it just seems different than actual debouncing.
Unread 06-03-2013, 09:25
As shown, it debounces only in one direction: it requires 5 ones in a row to switch the output to 1, but only one zero to switch back to zero (and stay zero until 5 more consecutive ones are seen).
If you want to debounce in both directions, change the second line to
if(output==0) output=truncate(ave+0.03); else output=truncate(ave+1-0.03);
Unread 06-03-2013, 22:58
foote stepped in
AKA: E. Foote
FRC #0868
If I understand what you're doing, .03 is a nice way to represent 2 ^ -5, and if you wanted more or less consecutive bits (allowing longer debouncing) you'd adjust the exponent accordingly.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
Unread 06-03-2013, 23:21
Originally Posted by efoote868 View Post
...if you wanted more or less consecutive bits (allowing longer debouncing) you'd adjust the exponent accordingly.
Yes.
