Go to Post Michigan teams will eat your souls. You have been warned. - MishraArtificer [more]
Unread 06-03-2013, 14:47
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Team 3647: Ultimate Ascent Robot
Originally Posted by Flak-Bait View Post
Nice! Are your cylinders spring loaded? We used 1.5" no-spring cylinders and had a problem building enough pressure to pull up to the bar. We could do it, we had to let our air build up after we put the hooks in the "up" position. Looks great guys- good job with the floor intake, wishing you a successful competition season!
The cylinders are not spring loaded, they are just the ones from the bimba PDV. Which does mean we have to have about 30-35 PSI left in the tanks for them to be able to lift after the buzzer. We are only using our air for lifting/lowering the intake plus the hanger so in our practice we usually have plenty of air.
Thanks!
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 06-03-2013, 15:06
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
I see, that's where we go wrong- we use air for every shot as well as our hopper. With that onboard compressor, you guys must be fine.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 06-03-2013, 15:12
Mk.32's Avatar
AKA: Mark
We were thinking about doing some kinda kicker for our shooter but decided like last year just a belt that ends as the disk enters to shooter would work fine. Also we have just learned to ALWAYS put the compressor onboard, last year we didn't and it was just a big hassle to deal with before matches and to find all the micro leaks.
Unread 06-03-2013, 16:09
Really sweet robot this season, Mark. You should be extremely proud of the work you do for your team.
Wish you the best of luck dude!
Unread 06-03-2013, 18:25
DonRotolo's Avatar
Back to humble
FRC #0832
Nice build.
Here is a thought: add some latex tubing pulling 'down' on the cylinder rods. You always have enough pressure to extend, so extra force won't be a problem, but that same force will help lift you with less than 35 psi...
