Re: Vex Pro Shifters
We are very happy with the ball shifters. The only issue as compared to a SuperShifter is that we needed to use a smaller output and larger wheel sprocket. Oh, and a SS can have a 4:1 range, or it can be like the ball shifter with a ~1:2.7 range.
We also had the output shaft come loose, but repaired it with adhesive. We especially like the weight and cost savings. |
They've worked extremely well for us. In regard to the question about WCD mounting, we made a custom gearbox plate to offset them from our tubes so that we could put the sprocket for our live axles directly on the output shaft. wasn't really a problem.
