Go to Post 30 point hang is brutal. Those who say it is easy are not thinking it through or are way smarter than the rest of us ... - Paul Copioli [more]
Unread 06-03-2013, 05:28
sretter's Avatar
sretter sretter is offline
AKA: Shaked
FRC #2231 (OnyxTronix)
sretter is on a distinguished road
Camera resolution might be too much for bandwidth?
Hi everyone,
My team is using the Axis M1011 camera with a resolution of 640X480,20 fps,(I think 30% compression)
Could there be a problem with the band width limit or it it ok?
If too much could it be enough to lower fps and increase compression?(We really want to use the current resolution)
Thanks!
Unread 06-03-2013, 06:46
Re: Camera resolution might be too much for bandwidth?
If you are using the default or LV dashboard, it includes an indication of the bandwidth being used and an LED that will be green, yellow, or red based on the value.
I thought there was a screensteps that showed how to display the bandwidth usage printed on the image, but I couldn't find it this morning.
I suspect that your camera settings are over the limit and will need to be either more compressed, lower the framerate, or both.
The bandwidth is proportional to the framerate, and pixels, so using the next lower size will cut usage by 4x. Compression is not a linear scale, so is harder to predict.
Greg McKaskle
Unread 06-03-2013, 07:40
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I'm not sure what compression we're using, but we can get 640x480@10fps using roughly 1.5 Megabits. We've verified it via Wireshark and our own counter in our Java display. It spikes to 2.2Megabits every so often though, thus we'll give it plenty of overhead.
GitHub
Unread 06-03-2013, 07:46
That is a good benchmark. 20fps would double the bandwidth at the same compression, which I'm guessing is more than 30.
I know the bandwidth numbers for the field were largely based on camera usage. The intent was to leave enough bandwidth for multiple lower resolutions cameras per robot or a single 640x480.
Greg McKaskle
Unread 06-03-2013, 11:16
sretter's Avatar
AKA: Shaked
Thanks guys!
I'll lower the fps and check.
From your experience was 10 fps good enough for the drivers to use?(Our camera is mainly used for vision but assisting the drivers could be nice as well)
Unread 06-03-2013, 11:38
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Just to use for comparison, we use the following settings.
320 by 240, 15 FPS, 30 compression.
Our bandwidth utilization is around 1.5 megabits.
This image is sufficient for on board image processing and Driver utilization.
Unread 07-03-2013, 03:00
sretter's Avatar
AKA: Shaked
Smile Re: Camera resolution might be too much for bandwidth?
Results after changing:
640x480 Resolution,10 fps,30% compression
Takes up 3 mb/s(according to the dashboard),
Changed settings don't seriously affect the vision proccessiong or drivers
Unread 07-03-2013, 10:43
sdaustin sdaustin is offline
FRC #3667 (The Mecanum Knights)
sdaustin is an unknown quantity at this point
I believe the default encoding for the M1011 camera is MJPEG. The camera also supports H.264 and MPEG4, which use dramatically less bandwidth.
Does anyone know if it's possible to configure the stream from the camera to the DS to use MPEG4? Doing so directly on the camera via its web config interface doesn't have any effect on the stream used by the DS - it appears the DS is over-riding the on-camera settings, probably via VAPIX or ONVIF.
Unread 07-03-2013, 11:03
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
At present, I've only found MJPEG support in the driver station. MJPEG is basically just a stream of standalone JPEG images (I-Frame Only) so the driver station just provides a JPEG decoding function.
H.264 is more complex and would also induce some delay in the picture (amount depends on specific usage). I'm not sure you would want that it even if you could get it.
Unread 07-03-2013, 11:06
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
No, we can only use MJPEG. The reason for that is that H.264 and the other format are pure video formats, whereas with MJPEG each frame is an individual picture that can be pulled out of the video feed and be processed immediately. H.264 and other formats only encode the changes between frames (which is why they use less bandwidth), meaning that if you wanted to process a frame with those formats you would need to process a dozen other frames to get one frame.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 07-03-2013, 11:34
In our case, the DS isn't doing any processing. It's just displaying the stream. We have a simple crosshairs overlay configured on the camera via its web interface that is used for manual aiming by the driver/shooter.
Does anyone know what implementation the DS uses to render the stream? Is it Windows Media, the Axis Media Control (AMC), QuickTime, something else?
Unread 07-03-2013, 13:25
One Eyed Man
The FIRST LabView updates have a Sub-VI in the getcamera VI to decode the JPEG to BMP. It then uses LabView to render the BMP on the DS. How Labview does it is a question for NI. I would assume the C++ & Java versions have a similar function.
Unread 07-03-2013, 15:32
The LV Dashboard decodes using NI-IMAQ. It takes in the JPEG stream and an allocated image. If the buffer contains a valid JPEG, it updates the image. The display is the built-in LV display that is specific to NI IMAQ image format, supports ROI and overlays, etc.
I believe the Java smart dashboard uses a media control, but that is a guess.
The NI-IMAQ doesn't include a codec for H.264 and other formats since they are rarely used in industrial settings. If you are going to use the H.264 with LV, delete the IMAQ display and use an ActiveX media control instead, update the camera CGI request and glue the two together.
Greg McKaskle
Unread 07-03-2013, 17:11
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
There is a ScreenSteps page at WPI on Measuring Bandwidth Use which you might find useful.
The FMS Whitepaper Rev.A also includes a table of expected camera use which I've reproduced below for convenience.
The FMS table suggests peak use of 4.3Mbs for the 640x480; 10fps; compression 30 configuration described below, somewhat more than the 3Mbs seen on the dashboard.
Unsurprisingly we found that the actual bandwidth used varies by about 20-30% depending on the specific image sequence being compressed. However counter-intuitively (at least to me) we noticed that bandwidth was higher for steady images and lower while the camera was moving quickly.
Edit: Daniel's explanation of MJPEG above supports this observation. In a moving image each frame is blurry so has less detail and can therefore be compressed more. But there is no compression gain from the frame-to-frame similarity of a steady image if each frame is compressed independently.
Unread 07-03-2013, 17:39
Greg McKaskle
Thanks Greg. That's exactly what I wanted to know, for future reference.
