Go to Post Do give credit to the mentors, because they make you who you are. - Arefin Bari [more]
Unread 07-03-2013, 22:40
Reggie335 Reggie335 is offline
AKA: Reginald
FRC #4297 (WeNoRobots)
Reggie335 is an unknown quantity at this point
Re: Programming Help.
Originally Posted by Ziv View Post
Well, there are certainly people here who'd love to help. However, first know that it'll be a lot easier to get help in person from someone at the regional. Then again, in the interest of getting as much work done tonight as possible, it'd be helpful to answer the following questions.
1. What language are you using? (I suppose if you're restarting you could switch if you like.)
2. What's you're robot like? What subsystems does it have? How do they move? Do they have sensors?
3. What do you need those subsystems to do?
4. Which parts of question 3 do you need help with?
I know a not-too-complicated program can be finished in under 3 hours with command-based Java, and I'm sure similar times are possible in the other languages. But to provide help, we need to know how to help first.
Good luck!
1.Language: Labview (Which Language Do you prefer )
2.Our DriveBase Consist of 2 Wheel Drive each Motor Is Controlled By A Jaguars (2 Jaguars total)
3.Our Shooter consist two Motor's Controlled By two Victor 888 Motor Controllers
4.Our Pneumatic System Consist Of Two Air Cylinder which are Controlled By One Double Solenoid Each
(Thanks For Helping Us )
