Go to Post Robotics is really preparing us for jobs at NASA. Look. We're past deadline, overweight, overbudget, and our project doesn't even work! - Oblarg [more]
Go Back   Chief Delphi > Technical > CAD
Unread 11-02-2013, 13:00
splatter's Avatar
splatter splatter is offline
Cant Spell Robots With Out Rob
AKA: Robert
FRC #0271 (Mechanical Marauders)
Team Role: CAD
splatter will become famous soon enough
Re: Syncing CAD files between multiple PCs.
we had and older dell desktop with windows xp and we set up a shared folder hooked the desktop up to its own router and when you want to share files we just log connect to the wifi of the machine.
FIRST Team 271
<Electrical, CAD>
http://www2.bayshoreschools.org/robotics/
Unread 11-02-2013, 13:04
Herbblood's Avatar
Herbblood Herbblood is offline
Knowledgeable
AKA: Ally
FRC #3044 (OxBE4)
Herbblood is an unknown quantity at this point
We end putting everthing on on e the maind students hdrives, that the school prvides us. It works if he's there, but if he's not its mostly on flashdrives.
Off to WPI!
Go OxBE4
Unread 11-02-2013, 13:29
Chris is me's Avatar
AKA: Pinecone
Google Drive is *okay* for small CAD teams that never work on the same files at the same time. Not a substitute for real version control.
Unread 12-02-2013, 21:46
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Our team started using github this year, and we love it. Pretty sure that we got
it either for free or at a discount through FIRSt, but don't quote me there.
It instantly detects changes between the main database and other computers, so syncing is easy. And having all our CAD files constantly up- to date is amazing.
It can even resolve issues with two people working on the same assembly at once.
Unread 13-02-2013, 22:21
yash101 yash101 is offline
AKA: null
Question Re: Syncing CAD files between multiple PCs.
Autodesk Inventor Vault client and server are the best options. Vault was built for this. Also. Google Drive works well. 5gB Limit, perfect, and the best thing is that Autodesk has an app, Autodesk WS. That allows you to edit DWG files from the web browser, but some drawbacks are that you cannot do 3D modeling here. If you can afford Autodesk Inventor Vault, it may be the best choice, knowing that you have such a robust network system in your school. Also, though it may be against your school rules (just like it is in my school), Creating a VPN server will allow you to run the inventor files directly from the server, as if they were on a flash drive.
Unread 08-03-2013, 08:18
team329CADteam's Avatar
team329CADteam team329CADteam is offline
FRC #0329 (Raiders)
Team Role: CAD
team329CADteam is an unknown quantity at this point
try using google drive. very fast and efficient
Unread 31-03-2013, 22:28
deeek deeek is offline
None #1329
deeek is an unknown quantity at this point
Originally Posted by Cory View Post
Currently Solidworks PDM
This year was our first year using Solidworks PDM as well. It is really a nice addition to the SW package. If anyone has a spare PC around and uses SolidWorks I would highly recommend it!
Unread 02-05-2013, 21:40
Arsenic335's Avatar
Arsenic335 Arsenic335 is offline
AKA: Tomás
FRC #2729 (Storm Robotics)
Team Role: Driver
Arsenic335 is an unknown quantity at this point
Originally Posted by AllenGregoryIV View Post
We actually have been using Google drive with pretty good success this year. We have an overall folder shared with all the CAD team and then each member has there own folder. When you need something you just copy it out of their folder (Don't edit directly it will break stuff). It's not a perfect solution but it's quick to setup and works decently enough if you don't have a server.
We had the same problem up until this year. We started using Google Drive this year and had great success as well. While I do admit it's not the best solution, it works, it's easy to use, and, the best part, it's completely free.
Unread 02-05-2013, 21:44
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
We've used dropbox with no issues this year.
Had a folder with the field + kit, and a folder with prototyping stuff, and a robot folder.
Unread 02-05-2013, 21:51
Yeah, it wasn't bad. We were always in communication with each other though and it helps to put like readme file or a To Do List file. Basically, make a lot of folders and whatnot. Worked out pretty well considering the large amount of parts we sent out to machine.
Unread 03-05-2013, 00:00
BrianArneson BrianArneson is offline
BrianArneson is an unknown quantity at this point
Has anyone tried Autodesk 360? It seems as if it's meant to do what you are looking for.
7 year FRC participant
Mentor on FIRST Team 662 - 2 years
Former student FIRST Team 4550 - 1 year
Former student FIRST Team 443 - 4 years
