Go to Post If I thank everyone that I want to, we might be here for a while - Karthik [more]
Unread 06-03-2013, 14:01
jrodprogramming jrodprogramming is offline
FRC #3521
jrodprogramming is an unknown quantity at this point
Using VEX Cortex to control FRC Robot help
Hi.
We read the thread about using VEX Cortex to control an FRC bot that was written some time last season. I am currently slightly confused as to how exactly the cortex should be connected to a Victor speed controller. I had it connected to the Digital Output using a male to male PWM cable and am running the Cortex itself off of a battery pack. I'm not sure what I'm doing wrong, but currently the Victor light still does not stabilize and continues to blink. Anyone know how to achieve this? (We're using this for our test robot while our other one is bagged).
Unread 06-03-2013, 14:11
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Using VEX Cortex to control FRC Robot help
Try connecting to one of the Motor ports.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 06-03-2013, 14:15
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Plug the PWM wire into one of the 8x three-wire Motor ports, and it should functionally exactly the same as a regular VEX motor.
You may have to recalibrate the Victor to the Cortex PWM output values to ensure the Victor operates over the full output range.
Art Dutra IV
世上无难事,只怕有心人.
Unread 06-03-2013, 16:01
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Originally Posted by jrodprogramming View Post
Hi.
As the post above mine said, use a PWM cable to connect to one of the motor ports (2-9, 1 and 10 will not work) and make sure that it is plugged in correctly. If memory serves, it is signal (white) on the inside and ground (black) on the outside. The motor can then be programmed using RobotC/EasyC as it normally would be with the VEX system.
Any post that I make expresses only my opinions. I do not represent the opinions of my team or of any entity affiliated with my team.
As a Mentor:
2016 - Engineering Inspiration at Greater Pittsburgh Regional
As a Driver:
2014 - Winner of Greater Pittsburgh Regional
Unread 08-03-2013, 12:59
FRC #3521
Do I need a jumper? I don't usually work with Cortex so I'm not sure exactly how it should be hooked up; I thought I didn't need a jumper but now I'm not sure. I tried the wires both directions, moved the ports, etc...the light on the Victor refuses to stabilize at all. I'm running the Cortex off the battery pack to avoid severing some wires to attach it to our power distribution board, does that matter?
Unread 08-03-2013, 13:02
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
It's also important to ensure you're sending the Vic a signal within the code.
Unread 08-03-2013, 14:02
FRC #3521
Update: Got the cortex working, thanks for all the help!
