Go to Post That is just ridonkulous. - Brandon Holley [more]
Unread 08-03-2013, 16:55
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Question Shooter wheel covering
Me and my team have been working ruthlessly over the past 2 weeks trying to make our shooter work the best we can. We are using a linear shooter with 2 andymark 8in rubber tread wheels on a mini cim each. We finally got it shooting decently(shooting from the back of the pyramid near the center of the field and only just making it into the 3pt goal) by putting surgical tubing around the wheels to make them like pneumatic wheels for grip and compression. This worked fairly well except that the tubing expands an awful lot and wears down to quicky. We have been experimenting with different ways of getting the same result as the surgical tubing that just doesnt wear as quicky but are at a loss, so we were wondering what you guys have been using on your wheels(if any)?
Unread 08-03-2013, 17:09
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Re: Shooter wheel covering
It appears you are wanting more compression as if you had pneumatic wheels. Why not put the compressible material on your stationary wall opposite the wheel?
Unread 08-03-2013, 17:14
AKA: Brian Wagg
FRC #2386 (Trojans)
We tried that today by using weather stripping however are results went from the 17 feet or so to 2 feet.
Unread 08-03-2013, 17:30
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
What does the wall look like opposite the shooter wheel? Are you using any form of grip tape? The KoP grip material works excellent.
A photo might help out here.
Unread 08-03-2013, 17:37
lcoreyl's Avatar
AKA: Milner
A picture would be good, a video even better.
-First off, are you saying you shot multiple (i.e. minimum 5) and they went approx the same spot 17ft away, then another minimum of 5 discs with the weather strip and they all landed at approx the same place 2ft away?
-With the weatherstrip, did you play with the compression? Do you have the ability to move the wall opposite your wheel to have any compression you like?
Unread 08-03-2013, 17:57
AKA: Brian Wagg
FRC #2386 (Trojans)
Yes that is how we tested
This here is it at an earlier stage in development however all we did after this was reduce weight, the rear wheel no longer has surgical tubing on it as when they both expanded they rubbed against each other, 2 mini cims now, and we have a Lexan top to prevent ride up of Frisbees. Unfortunately I don't have any recent pics . We will have a look into the KOP grip material. Unfortunately it is march break for us and we don't have access to our shop so no further testing can be done for a week . We did play with the compression as well with our adjustable wall
Unread 08-03-2013, 18:05
lcoreyl's Avatar
AKA: Milner
My suggestions:
1) get rid of the surgical tubing just to remove that as a variable (for this test anyways)
2) try (insert compressible material here) on the wall
3) play with the compression through a full range of barely grabs the disc to "whoa, you sure you want to compress the disc that much"?
-always shoot enough that you KNOW it is repeatably bad before moving on
repeat 2 & 3 with different materials
The disc slipping on the wheel AND the disc slipping on the wall are different variables and you will want to have an grasp on their effects to your shot.
Unread 08-03-2013, 18:14
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
This will not help with distance because the point of having a compressible material is to increase the time and amount of frisbee in contact with the wheel. If you don't make the wheel compressible, the frisbee will only touch at that one point where it and the wheel are tangent.
Unread 08-03-2013, 18:17
lcoreyl's Avatar
AKA: Milner
Have you actuallytried a compressible wall?
Unread 08-03-2013, 18:19
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
I believe the fact that you are also storing energy in the frisbee when you compress it can also have an effect on distance.
Any post that I make expresses only my opinions. I do not represent the opinions of my team or of any entity affiliated with my team.
As a Mentor:
2016 - Engineering Inspiration at Greater Pittsburgh Regional
As a Driver:
2014 - Winner of Greater Pittsburgh Regional
Unread 08-03-2013, 21:29
arun4444 arun4444 is offline
FRC #3760
arun4444 has a little shameless behaviour in the past
The problem is, any change you make you have to go through the tweaking process over again, how bad is the ware rate? how many Frisbees can you shoot before having to change the tubing?
cheers
arun
Unread 08-03-2013, 21:48
AKA: Brian Wagg
FRC #2386 (Trojans)
cheers
arun
We can get about 50 shots on 1 wheel. We don't think this is that bad as one of our old prototypes needed to be changed every 2-3. The issue is that it takes to long to go and change our wheel(about 10 minutes which is no good in eliminations). Can anyone think of a material that can act like the tubing but more durable? We are currently thinking of using andymark tread instead . Ill be looking around in Toronto tomorrow for insparation.
Unread 08-03-2013, 22:04
FRC #3760
one quick change you can make is make the wall flexible - so maybe thin gauge metal only fastened on two points - for a rubber-band effect, replicates to some extent what pneumatics do.
Somthing like:
http://www.youtube.com/watch?v=aszDpJW_8bA
but with only two hold-downs - the tension follows the Frisbee.
also you can try cutting up the latex and riveting it on - maybe that helps because it will reduce movement of the latex.
cheers
arun
Unread 09-03-2013, 00:14
lcoreyl's Avatar
AKA: Milner
Please also remember safety when you talk about attaching things to wheels that are already spinning beyond what they're designed for.
a little searching and you can find a pic on CD of what happens when tread separates from a wheel by pulling out of its rivets, but don't if you have a weak stomach.
Stay far from the plane of the wheel ("plane of death", "plane of destruction"), and use guards if you're going to experiment further with (cough) re-inventing the wheel.
Unread 09-03-2013, 01:06
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Can't believe this hasn't been suggested yet, but if you can get these in time...
http://www.andymark.com/product-p/am-0970.htm
Problem solved. Same size, you get the compression you need (even variable to some extent as you can play with the pressure of the wheels), and it should mount on the existing hole pattern of the wheels you're currently using.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
