Go to Post Thank you for participating. It'd be a blank website without all of you. :) - Brandon Martus [more]
Unread 09-03-2013, 00:29
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: THE HORROR! THE HORROR!
Hmm. You've got me curious. Can you give a general idea of what you have in mind? Is the purpose of the Jag to allow you to record data (via CAN) and shut off automatically so you don't have to babysit it?
Black Jags are serial controllable and have current control modes plus built voltage and current feedback. So all you would need for a battery tester is a serial port (or USB-Serial adapter), a serial to Jaguar adapter, a Black Jaguar that most every FRC team has 1 of, and a power resistor you can get at Mouser or your local electronics surplus store. Battery on the input side, power resistor on the output side, tell the Jag to dump X amps into the resistor, then record and plot your feedback. Primary difficulty is making the program to control the Jaguar. Either I'd need to figure out how to generate the FRC heartbeat, or you'd have to flash the Jag with custom firmware.
