Go to Post It sounds like "whirr" if you do it right, and "clack clack grunge snap @$@%^!!" if you don't. - dtengineering [more]
Unread 25-01-2003, 12:34
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Innovation First Site Down
ok, i'm sitting here trying to get to the innovationfirst.com site, and it's not working. i've heard that there was a MS SQL worm, and that Dallas was the worst hit, and from what i remember, Innovation First is in Texas, but i'm not sure how far from Dallas.
if anyone has the current OI documentation saved, could you please point me to it? we're trying to make a competition port dongle to control the robot in autonomous mode, but well, it's hard when you don't have a pinout (even a partial one).
i'm sorry if this has been covered tons of other places, but anything i've found is for last year's OI, not documenting the autonomous pin.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 25-01-2003, 13:07
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Yeah, Greenville (where IFI is located) is about 50 miles away from Dallas ...
I was just ready to sumbit a fairlylarge order from them and I lost it.
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 25-01-2003, 13:51
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Here you go, hope it helps.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 25-01-2003, 14:05
CHSguard72 CHSguard72 is offline
CHSguard72 is an unknown quantity at this point
Send a message via AIM to CHSguard72
Need pin guides for OI Inputs and RC Digital Inputs
The innovation FIRST Site is down, and i am in desperate need of the pin-guides for both the OI input ports, and the robot controller digital input port. If anyone has these, PLEASE HELP!
thank you from team 612
Unread 25-01-2003, 14:32
Manoel's Avatar
There's a picture of the digital pinout in the RC in the bottom, the OI Port is explained below:
In the four ports, it works like that:
Pin 1 +5V Aux (Fuse F2) [2,3]
Pin 2 Joystick Trigger Switch
Pin 3 X-Axis
Pin 4 Ground
Pin 5 -- See below --
Pin 6 Y-Axis
Pin 7 Joystick Thumb Switch
Pin 8 -- See below --
Pin 9 -- See below --
Pin 10 Aux Switch1
Pin 11 Aux Analog
Pin 12 Ground
Pin 13 Wheel
Pin 14 Aux Switch2
Pin 15 -- See below --
Below - Pins 5, 8, 9 and 15 are different for each port. For ports 1 and 3, they work as feedback LED's. For ports 2 and 4, they are the same as some switches in port 1 and 3. For example, pin 5 in port 2 is the same as pin 2 in port 3 (p3_sw_trig). If you need the pinout for those too, ask here.
Brazilian Machine
Team # 383
Unread 25-01-2003, 14:43
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Need pin guides for OI Inputs and RC Digital Inputs
I've (temporarily) put a copy of the RC Ref here:
http://kevin.org/robot_controller_reference_guide.pdf
and a copy of the OI Ref here:
http://kevin.org/operator_interface_reference_guide.pdf
These are sitting on my home server, where I have limited (128Kb/s) outgoing bandwidth. Please don't download it unless you really need it. In a few hours you should be able to get all of the files from here:
http://www.cvhsrobotics.org/resources.htm.
The page works, but the links won't because my work server is currently down.
-Kevin
Kevin Watson
http://kevin.org
Unread 25-01-2003, 16:05
FRC #2429
I just brought my work server back up, so if you need documentation, I probably have it cached here:
Now back to our regularly scheduled 'bot building...
-Kevin
Kevin Watson
http://kevin.org
Unread 26-01-2003, 01:14
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Worm!
I think that worm got my internet service provider on Saturday. I couldnt get on the entire day. "Invalid user name and password" "Invalid user name and password". It finally worked at 1:00am on Sunday.
Purdue Alumni
Cummins, Inc.
What do you use to make your team site!? activemx Website Design/Showcase 68 15-01-2003 18:32
NEW site dedicated to the UTC New England Regional! archiver 2001 2 24-06-2002 01:13
Yahoo! site listings archiver 1999 1 23-06-2002 22:26
Yahoo! site listings archiver 1999 6 23-06-2002 22:26
Innovation First is accepting pre-orders for the Control System archiver 2000 5 23-06-2002 22:19
