Go to Post I was a rookie last year, I didn't expect much. Now I got a taste of what it is, I want more. - davidthefat [more]
Unread 09-03-2013, 15:04
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Removing the feeder stations slides
Observed at NYC, FEEDERS have been removing the "slides" on the FEEDER SLOTS. Referees do not seem to have been calling penalties or cards on it. Anyone have any idea what's going on here?
http://i.imgur.com/ynSwcJk.jpg
Q&A has been asked.
Unread 09-03-2013, 15:45
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Removing the feeder stations slides
I noticed this too. Are they removing the top cover, or the whole thing?
Unread 09-03-2013, 15:57
PVCpirate's Avatar
PVCpirate PVCpirate is offline
FRC Data Nerd
AKA: Anthony Jennings
FRC #1058 (PVC Pirates)
PVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud of
I always assume that the field is supposed to remain set up the way it is described in The Arena, so I don't think it should be allowed:
Each slot has a slide attached to it on the FEEDER side of the plastic. These slides are 8 in. long and are at a 30-degree incline.
I can't find a foul that specifically relates to humans changing the field though. The closest I can find is G14, although that appears to be directed at robots, not humans.
My accomplishments with 1058:
2010 - Granite State Regoinal Winners, Galileo quarterfinalists, IRI quarterfinalists
2012 - GSR Chairman's Award winners
An incredible four years I will never forget
Unread 09-03-2013, 16:48
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
They're removing the colored plastic cover, which is held on by velcro. The clear plastic slide is staying in place
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 09-03-2013, 17:05
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
Good opportunity for lawyering. The FIELD is on the inside of the wall, not the outside.
I'll be interested to see how the management deals with this. I assume the generic "do the right thing" and the "no lawyering" rules would kick in.
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 09-03-2013, 17:32
AKA: Simon Bohn
In this case it seems pretty clear cut:
FIELD: the area bounded by and including the GUARDRAILS, ALLIANCE WALLS, LOW GOALS, and FEEDER STATIONS.
Emphasis mine
Unread 09-03-2013, 18:19
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Maybe G7 by delaying the game by modifying the field.
Maybe by not allowing frisbees to be fed into incomplete feeder stations. G35
Maybe a red card for egregious behavior for not following directions of field officials when asked not do that.
Unread 09-03-2013, 18:40
AKA: Simon Bohn
UPDATE: We were contacted by a FIRST representative and she said that question was answered before it could go through the internal channels and if anyone had seen the unofficial answer, it should be taken as such. Considering this, I've deleted the below quote, which was their draft of an answer to it. To fully redact their answer, they had to delete the question as well so we can ask it again if we wish, though I think Siri below answers it pretty well. The GDC's thinking in the unoffical answer was that it would be against G14 to modify the field.
Unread 09-03-2013, 18:58
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
No 5.5.4 cards; we explicitly allowed them to remove the velcroed-on corrugated covers under certain conditions. I'll let higher powers speak to how and why, but before the frenzy starts, it was fully sanctioned by the all relevant local field authorities.
Unread 09-03-2013, 19:02
PVCpirate's Avatar
FRC Data Nerd
Ah, so G14 does apply to people as well as robots. I don't have a problem if it was allowed by the NYC event officials, but now that there is an official ruling it should not be allowed in the future.
Unread 09-03-2013, 19:11
Becca334's Avatar
Becca334 Becca334 is offline
AKA: Rebecca
FRC #0334 (TechKnights)
Becca334 is a jewel in the roughBecca334 is a jewel in the roughBecca334 is a jewel in the roughBecca334 is a jewel in the rough
At the drivers meeting at the end of Day 2 they told us we could remove them if we wanted to. But then at the start of today they told us that we can only remove the cover if the cover was damaged and a referee OKd it. By the mid-end of the day lots of the covers were falling off from bent too much/velcro not working etc.
Unread 09-03-2013, 19:19
AKA: Simon Bohn
I don't know if there is an official ruling on it anymore. When I quoted Q&A, the question was there. I just checked and they deleted my question (along with the draft answer), so maybe there will be a team update. Very unusual.
Update: A FIRST representative called our main team contact and told her that the answer given was unofficial and they had to delete the entire question thread to fully redact the answer. She said we were welcome to resubmit the question but I don't really see a reason to, as Rebecca and Siri answered it.
Unread 09-03-2013, 20:37
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The issue of course is that the covers are made out of flimsy corrugated plastic and they deteriorate over the course of the regional till they end up blocking the chute and making it extremely difficult to get frisbees out. It's kind of sad that a practice feeder station made out of plywood would work better than the official field.
Unread 09-03-2013, 20:44
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
I noticed the issue becoming more of a factor as the competition went on in Palmetto. The covers were not taken off there and teams seemed to be capable of performing well. I know our feeder had a few issues here and there, but when do you not have to overcome things in FIRST.
Also note that the feeders don't help the situation. In my personal opinion the frisbees should not be stacked on top if the feeder slots. I think several things should happen: FIRST releases a 'beefed up' feeder slot cover, FIRST issues an update stating the covers cannot be removed, and the frisbees are no longer allowed to be stored/kept on top of the slots.
Just my opinion.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 09-03-2013, 21:08
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
In general modifying the field would be against the rules. If it is being done with the knowledge & consent of the officials then you really cannot penalize the teams for doing it regardless of the ultimate decision. Sounds like this was the case.
