Go to Post don't be grumpy. No one is allowed to be grumpy during build. - JaneYoung [more]
Unread 26-01-2003, 03:59
PBoss PBoss is offline
PBoss is an unknown quantity at this point
switches in order
Here is a piece of code in PBasic 2.5
IF p1_sw_top=1 AND p2_sw_top=1 then
p1_y=200
This means that at any given time, if p1 switch and p2 switch are pressed together p1_y=200, but here is my question:
Is there a way that you can program so that the switches will have to be pressed in order- first p1 switch and then p2 switch or vice versa- then only p1_y=200???
Unread 26-01-2003, 04:17
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Yes, you can declare a latch or memory bit that is set when the first button is pushed and cleared when the second button is pressed.
Tim Tedrow
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 26-01-2003, 09:04
PyroPhin's Avatar
PyroPhin PyroPhin is offline
None #0263
PyroPhin is on a distinguished road
yes, you can do that very simply, using 2 for, next loops:
sw1:
if p1_sw_top = 1 then sw2
goto endswich
sw2:
if p2_sw_top = 1 then dostuff:
goto endswich
Dostuff:
p1_y = 200
endswich:
the program will process the first loop, then only if that requirement is met, go to the second loop. if the requirement isnt met at either button, or at the second, not the first, it bypasses the dostuff loop ^.^
~Pyro
Squee!
Team 263, Aftershock:
Alumni, guy who comes back and fixes Krass's mistakes
Unread 26-01-2003, 10:45
FRC Key Volunteer Trainer
AKA: CrazyNate
Here's a bit of code which will do what you want:
'in variable declaration section
seq1_flag VAR bit
'in main loop
'Check 2nd condition first to allow for continuous action, and not just one loop
if p2_sw_top = 1 AND seq1_flag = 1 then run_seq1
'Check first condition
if p1_sw_top = 0 then skip_seq1
'if we got here, condition 1 is true, set flag
seq1_flag = 1
'jump out of sequence loop
goto seq1_done
skip_seq1:
'first condition is not met, clear flag
seq1_flag = 0
goto seq1_done
run_seq1:
'both conditions met, set value
p1_y = 200
seq1_done:
'end of sequence loop
Nate Smith
nsmith@smythsoft.com
Unread 26-01-2003, 15:50
PyroPhin's Avatar
None #0263
isnt that overkill?
~Pyro
Squee!
Unread 26-01-2003, 22:02
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
No. The code you posted doesn't actually take the order you pressed the switches into account. The switch variables don't get updated until you do a SERIN, so you need a way to keep track of stuff between the loops.
--Rob
Limit switches Team168 Programming 8 10-02-2003 16:22
Custom Pneumatics order form Andrew Schuetze Kit & Additional Hardware 1 10-01-2003 20:34
Team selector switches on ISAAC Lloyd Burns Robotics Education and Curriculum 0 17-12-2002 08:32
More than 2 aux switches in 1 port f22flyboy Programming 2 01-11-2002 14:44
Need help with custom switches archiver 2001 3 24-06-2002 00:35
