Go to Post In theory, this should work... Oops. - Eldarion [more]
Unread 09-03-2013, 19:33
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Pyramid variation
Now that we've gotten through two weeks of regionals, I wanted to see what folks have been noticing in terms of variation of height on the competition pyramids. I've seen stray posts here on CD, Facebook, etc. claiming 1" or more of variation, but I want to confirm if such findings are true. Please share any measurements or observations you have.
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 09-03-2013, 19:45
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Re: Pyramid variation
Palmetto pyramids were within 3/8". That is a typical tolerance for most FIRST fields. Some of the variation was probably due to the flooring underneath. You could see a gradual change in elevation in the carpet when on the field.
We try to keep these type of tolerances in our design. Call it "room for error". We typically expect up to a 1/2" difference in field vs drawings. Overall though the two pyramids at Palmetto on the field and the practice pyramid were within "tolerance".
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 09-03-2013, 19:46
EricLeifermann's Avatar
EricLeifermann EricLeifermann is online now
That was a short break
FRC #2826 (Wave Robotics)
Team Role: Electrical
The pyramids at Northern Lights were 28 5/8 in from the bottom of the bar to the floor.
2012-2016 Wave Robotics Team 2826
Unread 09-03-2013, 19:51
dcarr's Avatar
#HoldStrong
AKA: David Carr
The official measurements dictate 30" to the center of the bar, right? So in fact, this was only 0.625" out of range if I understand correctly. Still not too bad.
I'm looking to see if there are any documented cases in which the pyramid was dramatically off (i.e. close to or greater than 1")
Our practice pyramid is about 3/8" off on the bottom, which I'm assuming (hopefully correctly) is within the range that could be expected at a competition and what we should be able to handle.
Team 3309
Team3309.org
Unread 09-03-2013, 21:57
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
30" to the center minus a 3/4" radius is 29-1/4" to the bottom of the bar, so it was low by 5/8".
Section 2.1 Overview
Fit and tolerance on large assemblies (e.g. the LOW GOALS) are ensured only to within ¼ in.
That would be 3/8" out of the tolerance range.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 09-03-2013, 22:34
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
The problem we have been grappling with is that the pyramid pieces all "slide" together and there are no pinned connections between the assembled sections. During climbing, the sections pull apart and the pyramid turns into some sort of phsychadelic rhombus. This has been especially evident in our case as we induce a significant cantilevered load off the side of the structure. The reaction of the FTA/Field staff seems to be a shrug of the shoulders. It has been a dissappointment for us thus far and has forced us to rework several parts of our climbing mechanism to deal with the variation. A cordless drill, hammer, drift and some roll pins would go a long way here.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 09-03-2013, 22:44
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
We measured as low as 28-3/4 at Orlando.
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 09-03-2013, 22:48
tim-tim's Avatar
AKA: Tim Miedzinski
To be fair, FIRST was upfront with how the pyramid was assembled. It's not like it changed over the season. Adding something now could affect many other teams.
The RoboBees
Unread 09-03-2013, 23:02
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Identical to this at Hub City.
Unread 09-03-2013, 23:08
fox46's Avatar
So the pyramids are supposed to come apart during game play and any attempt to make them stay together would affect other teams? How many other teams banked on them comming apart?
What would you say if the pyramid collapsed? Is it our fault because we should have known it would collapse based on how FIRST designed it?
Unread 09-03-2013, 23:11
Kristian Calhoun's Avatar
Kristian Calhoun Kristian Calhoun is offline
Celebrating 20 years of 25
FRC #0025 (Raider Robotix)
Kristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond repute
Send a message via AIM to Kristian Calhoun
The measurement from the floor to the bottom of the lower rung on the pyramid used at Hatboro-Horsham last weekend was 28 1/4".
Raider Robotix: Home | Twitter | Facebook | Instagram
Brunswick Eruption: Home | Twitter | Facebook
Unread 09-03-2013, 23:12
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
The way the field interacts with robots has always been part of the challenge of the game. The FRC staff can not and should not be expected to build a field around a single teams robot design.
In 2005 I witnessed multiple Scoring pyramids pull up from the floor because of how many tetras were scored on these, that could have never been predicted (229 at FLR for example). Also in 2007 with the rack, who ever would have thought a team would have been able to move that completely, it just isn't foreseeable.
With the way the field has to be designed to be durable and also transportable, I think the designs this year are very well done, being able to give the most unobstructed goal, and climbing ability to all teams evenly.
-Michael Dessingue
Unread 09-03-2013, 23:26
mwmac's Avatar
mwmac mwmac is online now
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
It is week 2 and I saw MC's standing on the "30" inch bar at two regionals today. At a minimum, First should unequivocally end this practice...
Unread 10-03-2013, 00:18
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
The MCs are told to stay off the pyramids for the most part but for special times such as eliminations.
Unread 10-03-2013, 00:23
The MCs should be eligible for G02 fouls. (A Yellow Card for team members climbing onto the pyramid, FWIW.) Second card means that another volunteer MCs for a couple hours. Wait, I'm not sure that's a penalty for the MC... How about a second card means the MC stays inside the netting for a match or two?
