Go to Post You can take the man out of FIRST, but you can't take FIRST out of the man. - George1902 [more]
Unread 10-03-2013, 01:32
NXTGeek's Avatar
NXTGeek NXTGeek is offline
AKA: Malachi
NXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to behold
Re: Pyramid variation
The pyramids at SD were noticeably different from each other, with the red pyramid's 10pt bar being too low to the ground. A number of teams were having problems with that and complaining to refs.
2013 -Team 3476
Champion (Fall Classic)
Champion (Battle at the Border)
Finalist (Indiana Robotics Invitational)
Newton Division CHAMPIONS (Worlds)
Wild Card as Finalist Alliance Captain (Inland Empire -> Worlds)
Innovation in Control Award (Inland Empire)
Industrial Design Award (San Diego)
Semifinalist (San Diego)
2012 -Team 3476
Champion (San Diego -> Worlds)
Excellence in Engineering Award (San Diego)
2011 -Team 1425
Engineering Inspiration Award (Portland Autodesk -> Worlds)
Finalist (Portland Autodesk)
WFFA (Tim BD, Portland Autodesk)
Finalist (Seattle Olympic)
Entrepreneurship Award (Seattle Olympic)
Unread 10-03-2013, 03:04
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Sounds like it will be necessary to test on both pyramids if possible - with the way our Thursday is shaping up (6+ hours of work at last count), this might be tricky
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 10-03-2013, 03:29
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Originally Posted by mwmac View Post
It is week 2 and I saw MC's standing on the "30" inch bar at two regionals today. At a minimum, First should unequivocally end this practice...
I saw an FTA who shall remain nameless do this to remove a 5 Point Frisbee when it took the field crew more than 5 min to figure out how to do it the right way
The problem I saw most was the sway from side to side at least on the practice one. With all the compounding error the top moved at least a couple of inches side to side when you grab the side bar, it was quite shocking, not something I would want to climb...
And if you have not seen one yet, this is what they look like taken apart.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 10-03-2013, 07:39
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Originally Posted by jspatz1 View Post
Identical to this at Hub City.
I was told one Northern Lights pyramid was 30 3/8" to the top of the bar and the other was 30 1/2" to the top of the bar. I believe this field is going to Kansas City next. Our robot is about 28 3/4" high and we were able to drive under.
Unread 18-03-2013, 11:13
mwmac's Avatar
mwmac mwmac is offline
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
Did anyone encounter more level one bars lower than nominal specs during Week 3?
Unread 18-03-2013, 12:12
wesbass23 wesbass23 is offline
FRC #1732 (Hilltopper Robotics)
wesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud of
The 10pt bars on each side of the pyramids at Boilermaker were all different heights. The lowest being 28 and 1/2" preventing us from going underneath a couple bars and just barely scraping by on the others. We managed to lower the highest point on our robot enough to slide under all bars by the end of the regional.
Unread 18-03-2013, 12:18
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
At Greater Kansas City, when I measured Thursday morning, they were pretty close to being in spec. The red pyramid was about 29.75" to center, and the blue pyramid was about 29.5" to center.
Academic Student (Forever)
Unread 18-03-2013, 12:24
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
When I measured at Lake Superior, the two pyramids were virtually identical... no more than 1/8" off in height for any of the level 10 bars. They were all about 1/4" below the ideal, however.
Variation should be expected and planned for. When we built our robot, we planned for an extra 1" between the top of the robot and the bottom of the lower bar, in order to ensure we could go under. We also built in an extra couple of inches of reach, in case the spacing between the bars wasn't exactly 30". As a result, variation in the pyramid design wasn't even something we thought about at the regional - the climb just worked.
2016: Lake Superior WFFA
Unread 18-03-2013, 12:28
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
We (FRC Team 1501) robot was 28.5 to the top of our lifting hooks. When going under the pyramid they would scrape the bottom of the bar. We had to mill off some of the hook.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 18-03-2013, 12:58
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Having been around on Wednesday to help setup 2 practice pyramids and see the field pyramids set up as well, I have one theory as to their height variation. When assembled, the multitude of slip joints do have some slop/play in them. The four legs can be allowed to flex/spread outward, or can be forced inward before their location is fixed on the floor by the wooden inlays, carpet, and tape. This can lead to some variation in the horizontal bar height depending on how much they are or are not allowed to spread. In KC the legs of the pyramids we helped with were cinched inward with a winch strap all around before the foot flange locations were set, and these crossbars ended up very near the 30" to center spec. The crossbars we saw in Hub City were all significantly lower.
Unread 18-03-2013, 13:00
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Wait a second -- FTA's at other events actually let teams MEASURE field elements???
Any time I've asked to do so at Virginia or DC, even on practice day, I've been told 'no'. I don't know why -- it seems to me that it would only help all FRC teams if the FTA's made official measurements and then posted them for all teams to see.
GitHub
Unread 18-03-2013, 13:05
Nate Laverdure's Avatar
FRC #2363
I believe this is new for 2013.
Originally Posted by 5.5.7 Measurement
The ARENA will be open for at least one (1) hour prior to the start of Practice MATCHES, during which Teams may survey and/or measure the FIELD. The specific time that the FIELD is open will be communicated to Teams at the event. Teams may bring specific questions or comments to the FTA.
Unread 18-03-2013, 13:08
Jared Russell's Avatar
Taking a year (mostly) off
Check out rule 5.5.7 (new for 2013)
The pyramids at Chestnut Hill were close to spec - about 28.75" from floor to the bottom of the low rung. At Hatboro-Horsham, we measured as low as 28.25". The same exact field (the MAR field) was used at both events.
I think the discrepancy is caused by how tightly the sides of the pyramid are pulled together when it is being attached to the floor. At Hatboro-Horsham, there were noticeable gaps between the corner pieces and the horizontal bars (e.g. the connector pipe was visible). At Chestnut Hill, everything seemed much tighter (virtually no gaps). The gaps would let the corner pieces sit at a shallower angle relative to the ground, causing the pyramid to "shrink" in the vertical direction.
Unread 18-03-2013, 13:11
JesseK's Avatar
FRC #1885 (ILITE)
Hmm, must have glossed over that section. This is awesome! We're close to the 28" hard limit I put on us, so it'll be nice to know if we can't drive under one of the 8 bars.
GitHub
Unread 18-03-2013, 14:21
mwmac's Avatar
JWBWIFWWWADD
AKA: Mike MacLean
I also overlooked 5.5.7 and believe it is very good news that team personnel can verify pyramid bar height.
However, I also believe that the simplest solution to pyramid variability would be an amendment to the playfield setup procedure for FTA's requiring a height check and adjustment of the base plate positioning. This change could help relieve teams of the need to perform ad hoc modifications to their robots that may otherwise prove to be completely unnecessary at future events. Just my .02
BTW,
I am available to assist with any field setup adjustments in Utah and Spokane...Just pm me..
