Go to Post This is why I love this game. It's like high speed chess with flashing lights and lots of noise. - Karthik [more]
Unread 07-01-2002, 18:33
techknights's Avatar
techknights techknights is offline
#0334 (Tech Knights)
techknights is an unknown quantity at this point
Send a message via ICQ to techknights Send a message via AIM to techknights Send a message via Yahoo to techknights
Post whats a PC ?
how did u people hook up ur robot to a pc
- hairloss101@yahoo.com ICQ# 121488310
http://www.geocities.com/bthsknights
maDGag [DT]
216.254.95.136:27910 q2
Unread 07-01-2002, 18:40
Dan 550's Avatar
Dan 550 Dan 550 is offline
Behold the Awesomeness!
AKA: Dan Richards
#0550 (BattleTech)
Dan 550 is on a distinguished road
A PC, otherwise known as a Personal Computer, is that beige box your monitor is hooked to. To hook a PC or a laptop or even a Palm Pilot to the Operator Interface, you can connect it via one of the included 9-pin serial cables to the Dashboard Port. Using a dashboard viewer, downloadable from many sources including InnovationFIRST . There are various dashboard viewers, and some people have written their own. I'm sure somebody will elaborate on the other programs...
Unread 07-01-2002, 18:41
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
use a serial cable and connect into the serial port on the back of your computer. Make sure there are no other devices such as a palm hot sync or anythign else that has the COM port open.
If you have difficulties post back on here again and i'm sure we can help you
Tom
Unread 07-01-2002, 18:48
Dan 550's Avatar
AKA: Dan Richards
#0550 (BattleTech)
Check your serial for marshmellows...
Your free serial port is usually COM2, as most BIOS chips set your modem as COM1, but just to be sure, check your system properties. If you're using a Mac, buy a serial-USB adapter, so your serial cable can be plugged into your USB port. They're sold all over for under 20 bucks. The InnovationFIRST dashboard program asks you which COM port to use, as does the Basic Stamp pBasic program uploader, but you'll be going throught that stuff after you finalize design.
Unread 07-01-2002, 18:58
thnks
thank you
[always wondered what the gray box was, ieh]
in the 2001, everything that was opertated by joystick other than the Drive was impossible to control, jerked too much.
we're considering automating such processes(if our design requires it)
thanks you once again
- george
maDGag [DT]
