Go to Post Note to self: Go to IRI sometime. - [more]
Unread 26-01-2003, 11:43
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
I wanna know how much those huge metal beams weigh.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 26-01-2003, 11:46
Mullen's Avatar
Mullen Mullen is offline
FRC #0573 (Mech Warriors)
Mullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of light
i dont see this robot as doing very well for king of the hill, i might be mistaken but if the arms dont have contact with the platform i see your robot spinning around when someone goes after the end of your arm
2002-2003 : 573 Mech Warriors: Student
2005-2007 : 1504 Desperate Penguins: Mentor
2012 - 2016 : 573 Mech Warriors: Mentor
Unread 26-01-2003, 14:38
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
the two beams with the centers in them weigh in at 35Lbs.
Just think if you get these long arms spinning like a top and someone tries to come close what do you think is going to happen.
the low center of gravity and the way the tracks are we have pretty good traction on the top of the ramp.
the point is not to be at the top until the end of the match. Full speed with arms out will push a couple of robots off the edge.
the arms and a strong robot will be good to knock over anybody stack even if they try to stop us. remember if your robot is touching any part of your stack that stack does not count. if a robot pushes into your own stack then you lose those points.
This is just some of the thing a strong robot can do. The field is open due because our robot can go under the bar so it would be hard to block
for those fast robot that knock the center stack down quickly our arms are wide enought to push them back up and over the ramp.
Unread 26-01-2003, 14:53
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Not if they have a firm hold. Track systems are good on top of the ramp and on the carpet. The ramp slopes however poses a problem. One of the reasons for having a track drive is for more points of contact. At the top and the bottom of the ramp you lose the advantage contact points, and you are no different than a four wheel drive robot. So, if a robot on top has a firm hold close to the edge of the ramp, odds are your tracks are no advantage. Note: the center idle wheel could also cause you to teeter at the top.
Unread 26-01-2003, 15:53
Explain exactly what you mean by this.
Greg
Unread 26-01-2003, 16:37
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
DId you say 7' 2"?
With that span and the side area by the bars only being 6' wide a see a small problem with going under the bar.
Unread 26-01-2003, 16:39
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
looks to be a very simple robot. which is good, as simple robots are easier to fix, and they seem to break less often than complex ones. The tracks will give you guys plenty of power and traction. I dont know how well those arms will be at blocking robots, bu they look like they could be hepful in herding boxes/ stacks around. Nice job. Good luck
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 26-01-2003, 17:23
BillyGoats BillyGoats is offline
Paper Eater
None #0061 (Intimidators)
BillyGoats can only hope to improve
Send a message via AIM to BillyGoats
Thank you Mr.Norton for explaining every thing, there are some doubters out there in this crowd
Unread 26-01-2003, 19:01
Christine G.'s Avatar
Christine G. Christine G. is offline
Christine G. is on a distinguished road
DId you say 7' 2"?
That is with the arms fully extended. Think about it if we were 7'2" to start we wouldn't fit in the box!
Unread 26-01-2003, 19:14
Walter_Jr Walter_Jr is offline
Walter_Jr is an unknown quantity at this point
Send a message via AIM to Walter_Jr Send a message via Yahoo to Walter_Jr
Yes but if we come up the ramp at full power we will just go through you..... And i know that our driver has no problem doing that we have destroyed other robots in the past!!!!!
Unread 26-01-2003, 19:32
D.J. Fluck
Posts: n/a
Um yeah, Last I checked I don't think you are literally supposed to destroy your opponent, but what do I know.
Unread 26-01-2003, 19:41
Yes well stuff happens at time!!!!
Unread 26-01-2003, 20:21
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
yah...i thought that too...
Purdue Alumni
Cummins, Inc.
Unread 26-01-2003, 20:24
Well we are not out there to destroy anyone just to have some fun and we are going to be the KING OF THE HILL and thats the way we have come up with staying on the top...
D.J. Fluck
Posts: n/a
Not since I've been in FIRST. Ive seen a few collisions that caused some breaking, but not intentional damage..
Yeah, which would lead to DQ's if the refs believe is necessary
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
