Go to Post CHALLENGE: A dozen Krispy Kreamers to the first team to make a three-pointer during a break at an NBA game. - Natchez [more]
Unread 10-03-2013, 17:04
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
coverting old Crio code to new Crio?
Greetings,
What does it take to convert code from the original crio to the new crio II?
We would be using this years imaging tool and C++ libraries.
Unread 10-03-2013, 17:09
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Re: coverting old Crio code to new Crio?
If you have the old code all you would have to do is load the code in Wind River and reimage the Crio. After you reimage it just build and download your code.
Unread 10-03-2013, 17:12
To code, there isn't any noticeable difference between the two cRIO models.
The newer model has more memory, some additional NI services are available, etc., so going backwards might present some limitations, but not going from the 8-slot to the 4-slot.
Depending on the vintage of the code there will be API changes and calling argument differences that may need upgrading.
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The code isn't any different, and if you're only deploying code and not debugging it, there isn't any difference. The only difference is if you're debugging code, you have to set up your target with a different image file, and your debug setup is similarly different.
Unread 10-03-2013, 17:28
wilsonmw04's Avatar
Coach
just so that I understand:
Our practice bot is running the old crio and the competition bot is running the newer version. From what I am hearing you say, there isn't anything we need to do to the code we developing to transfer it from the practice bot to the one in the bag? We have taken great pains to keep all the I/O and motor connections the same in both. I would just hate to run into something really, really silly on Thursday.
Unread 10-03-2013, 17:58
That's a direct transfer. No special conditions to running the same code on each machine.
Unread 10-03-2013, 18:01
wilsonmw04's Avatar
Coach
Awesome. Just what I wanted to hear. :-)
Unread 10-03-2013, 19:49
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
You have to define a different target for workbench to connect to to download, run or debug your program. See the "Getting Started With C" guide, page 33. The difference is the kernal image file:
2. Select a Kernel Image file by making sure the "File" radio button is highlighted and clicking
Browse. The file is located in the WindRiver install directory in the WPILib top level directory called
“C:\WindRiver\WPILib\”. Select the file that matches your cRIO version, either cRIOFRC_vxWorks
(8-slot cRIO FRC) or cRIOFRCII_vxWorks (4-slot cRIO FRCII).
Brian K
Team 1225 Robotics Mentor
