Go to Post Never should an idea be ridiculed, because ideas are exactly that just an idea. - Tim Delles [more]
Unread 10-03-2013, 18:01
Merfoo's Avatar
Merfoo Merfoo is offline
FRC #0955 (CV Robotics)
Merfoo is an unknown quantity at this point
Autonomous auto stopping
At regionals does fms enable autonomous then disable disable autonomous? So that if you had an autonomous 20 secs long only 15 secs of it will execute, or will the whole thing execute and you would get a penalty?
Unread 10-03-2013, 18:47
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Autonomous auto stopping
Nope. FMS just tells your program "Hey, your teleop now!". Your program doesn't need to respond in any way. Your robot could be fully autonomous if you really wanted to.
All opinions are my own.
Unread 10-03-2013, 18:51
Merfoo's Avatar
So if the autonomous was 20 secs only 15 would be executed then.
Unread 10-03-2013, 19:03
AKA: Joel Gallant
No. Autonomous (at least in Java) will run until it is finished. There is no way a method's execution can be "stopped".
Unread 10-03-2013, 19:11
Merfoo's Avatar
Ok thanks!
Unread 10-03-2013, 19:38
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Would just like to point out that if you're using the Command-based template there is a line in the RobotMain class under TeleopInit() that cancels the autonomous command. If you want it to keep running, delete that line.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 10-03-2013, 22:27
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
If you're using the Iterative template as it's intended (meaning periodic() doesn't hang), then your autonomous mode code will be automatically stopped when you leave autonomous mode. In the Command-based setup, since the Scheduler handles running everything, you have to make sure you cancel any Commands if you don't want them to keep running (the default template does this). SimpleRobot gives absolute control, and it makes it your responsibility as the programmer to check for the current mode and exit when necessary.
I code stuff.
Unread 11-03-2013, 16:26
CodeYeti's Avatar
CodeYeti CodeYeti is offline
FRC Addict
AKA: Matt Coffin
CodeYeti is an unknown quantity at this point
Well, if you really wanted to design it this way, then you could have things running in threads, then interrupt them, or set a boolean and have them return. That was part of my team's architecture last year.
