Go to Post Seriously I didn't think that "FIRST, it's the WWF for smart people" would ever catch on. - Schnabel [more]
Unread 19-02-2013, 18:18
megmeg megmeg is offline
FRC #3659
megmeg is an unknown quantity at this point
Exclamation Running code wirelessly
I need help running the program on the robot. How do I send the program through the D-Link? Or do I have to hook up the computer directly to the cRIO? I just started programming this year and there aren't any members with programming experience any better than mine on our team. If anyone can walk me through this I'd really appreciate it.
Unread 19-02-2013, 20:16
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: Running code wirelessly
you can setup the D-Link to act as an access point. There is a guide to configuring your D-Link. http://www.usfirst.org/sites/default..._08_13_195.zip
http://wpilib.screenstepslive.com/s/...o-for-home-use
Unread 10-03-2013, 19:31
FRC #3659
Thanks, the link was very helpful. However, when I try to configure the bridge, it shows this,
"Configuring computer IP address
Checking for bridge at expected IP addresses
Bridge found at default IP address
Bridge login failed"
Do you have any suggestions for how to fix this?
Unread 11-03-2013, 11:34
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
You need to do a hard reset. The utility or the setup instructions should have instructions. I can't remember how off the top of my head.
Unread 11-03-2013, 12:12
FRC #3659
I followed the instructions for resetting it in the bridge configuration tool, but after I did it, that is the message it gave me. I'm not sure if I didn't do the reset correctly or what, but it still hasn't worked.
Unread 11-03-2013, 14:34
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Try setting the configuration tool to run as administrator in compatibility mode for Windows 7. Even if you're using Windows 7 already. For whatever reason, bridge configuration wouldn't work for me on the classmate until I did so.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 11-03-2013, 17:58
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
Im just curious... Do you have DHCP setup on the dlink and if not did you set ur computer to a static ip of 10.XX.YY.ZZ (XX.YY is your team number and ZZ is what number you want that isn't 1, 2, 9, or 11)
Unread 14-03-2013, 19:20
AlexBrinister AlexBrinister is offline
AKA: Alex Brinister
FRC #1768 (RoboChiefs)
AlexBrinister will become famous soon enough
To COMPLETELY reset the D-Link, do the following:
1. Hold the reset button for 30 seconds while it is still turned on
2. Unplug the D-Link while still holding the reset button. Hold it for another 30 seconds
3. Plug it back in while still holding the reset button.
That should do it.
The default address of the D-Link is 192.168.0.50. You should statically set your IP to something like 192.168.0.51. So:
192.168.0.51
255.255.255.0
192.168.0.50
8.8.8.8
Then run the utility and you should be all set.
Alex Brinister
Unread 18-03-2013, 16:54
FRC #3659
What is DHCP? My computer is set to 10.36.59.6, but it hasn't worked so far.
Unread 18-03-2013, 16:58
FRC #3659
That should do it.
192.168.0.51
255.255.255.0
192.168.0.50
8.8.8.8
Alex Brinister
I tried to do this, but the configuration utility keeps putting a pop-up that says,
"Bridge configuration failed: Bridge login failed
Please reset the bridge and try again"
Then when I close the pop-up it keeps giving me the same message that I posted before.
