Go to Post I always get a little stressed as arm operator, especially with Paul Copioli standing behind me screaming at me. - JohnnyB [more]
Unread 11-03-2013, 20:17
robox89's Avatar
robox89 robox89 is offline
AKA: Kevin
FRC #3542 (S.P.E.E.D. Robotics)
robox89 is an unknown quantity at this point
4 cim motor programming in labview
My team usually goes with two drive motors per andymark toughbox. This year we want to change to two cims per toughbox. How do teams program this so that motors run in unison? I program in labview. Any suggestions? Thanks!
WARNING!FIRST IS VERY ADDICTIVE
Unread 11-03-2013, 21:43
Owen Makin Owen Makin is offline
FRC #1972
Owen Makin is an unknown quantity at this point
Re: 4 cim motor programming in labview
Do you want to do tank? arcade?
Unread 11-03-2013, 21:48
robox89's Avatar
AKA: Kevin
Tank drive if possible
Unread 11-03-2013, 22:11
The "proper" way is to replace the Open 2 Motor Drive with Open 4 Motor Drive in the Begin vi.
The easy way is to leave all the programming the way it is and use PWM Y-cables to control two speed controllers from each of the left and right drive motor PWM outputs.
Unread 11-03-2013, 22:20
robox89's Avatar
AKA: Kevin
Ahh! That makes so much more sense! Thank you!
Unread 14-03-2013, 18:05
NeatNit's Avatar
NeatNit NeatNit is offline
Alumni Programmer
FRC #1577 (Steampunk)
NeatNit is an unknown quantity at this point
I love this way; it feels so clean for some reason. It made me smile when I first saw it.
