Go to Post How many programmers does it take to change a light bulb? None. They'll just say it's a hardware problem. - crafty [more]
Unread 11-03-2013, 22:11
Re: 4 cim motor programming in labview
The "proper" way is to replace the Open 2 Motor Drive with Open 4 Motor Drive in the Begin vi.
The easy way is to leave all the programming the way it is and use PWM Y-cables to control two speed controllers from each of the left and right drive motor PWM outputs.
