#12
Re: Curved Shooter help
What PSI do you have in the pneumatic wheel?
Is the 1" of compression just the disc or a combination of the disc and wheel? Do you use the 1" compression the entire time the disc is in contact with the wheel or only the last several inches before release (eg. does compression increase as it moves through the curved shooter)? Does your shooter "eat" discs (eg. cause unusual wear)? |
