Go to Post I am used to politicians getting up and being blowhards. - Steve W [more]
Unread 12-03-2013, 01:28
Chris is me's Avatar
AKA: Pinecone
Re: OPR after Week Two Events
Originally Posted by Ed Law View Post
The OPR is a good representation of how good a team is this year. Without this coopertition award and coopertition points and weird ranking system, every team is trying to score as much as possible. However for regionals with lots of teams and not that many matches, there is still a lot of luck of the draw and the ranking will become meaningless. In that case, the OPR will still tell the truth about a team because data does not lie, only people do.
I did a little work after comparing to our actual scouting data, and it seemed while teams like ours had a reasonably accurate OPR, it's really easy for one's OPR to balloon this year, so in a regional ranking sense it's less accurate overall. Technical fouls and fouls aren't removed from the data. Teams that have a playstyle that draws fouls, or just played worse opponents, get an advantage in OPR.
At WPI, a few teams happened to have their non-functional matches paired with other good teams, and OPR doesn't really know how to separate that out. Additionally, defense is huge this year, making this game less separable than other games. So while our average contribution to a match might be close to our OPR, other teams were a ways off in one direction or the other due to scheduling oddities or hella technical fouls.
Unread 12-03-2013, 10:16
Basel A's Avatar
Basel A Basel A is online now
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Originally Posted by Siri View Post
If the information is available by match (which I'm not sure it is), does it inherently increase accuracy? The only DQ I've seen so is from G27. Not that DQs are common in any sense, but a robot that G27s could well have been a major contributor to the match score. (We were once red carded at an off-season when our robot went haywire at the end of a match we'd helped win.)
This scoring contribution is not true of other potential DQs, for instance the entire team no-showing or playing without clearing inspection, but it does apply for some. It could work if you had Disable information or no-show robots (vs 5.5.6 no show teams), but DQ might be a wash this year.
Sorry, I meant to refer specifically to no-show DQs (which were specifically mentioned by the previous poster). I don't think there's match-by-match information on DQs, let alone reason-for-DQ information.. Basically, you're right.
As for how well OPR is doing, the metric I typically use is % qualifying matches predicted correctly. I have 2013 OPR nearly 1% ahead of 2012 this time last year (81.5% vs. 80.6%), though the result isn't statistically significant (fwiw, p=0.29).
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 12-03-2013, 13:36
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
BaselA,
So do you sum the 3 team alliance OPR scores and then use the highest value to predict the match winner?
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 12-03-2013, 13:56
Basel A's Avatar
AKA: @BaselThe2nd
Originally Posted by marccenter View Post
BaselA,
Yes. There are some problems with this method (e.g. in 2011, when 3 teams with great minibots were on an alliance), but I don't think there's a better way to do it.
Also, just for fun, 2012 OPR (used teams' average of all event OPRs, but they're all pretty similar) is predicting 2013 matches at about 61% (counting any rookies as OPR = 0). Thanks to Ed for the OPRs and Ether for the Twitter Match Data. Not sure what I'd do without you two.
Edit: I don't want to post too many times, but there's a couple different things here. One is OPR as a tool to predict what will happen. Ed's reply below is pretty much exactly what I do for predicting matches (except realtime OPR; that's something I'd like to do in the future). In this case, I'm talking about how well OPR evaluates teams this year vs. other years, for which I used post-event OPRs. You can't hit 80% predicting matches without realtime data.
-Paul Copioli
Unread 12-03-2013, 14:16
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
BaselA,
I actually use a few ways to predict match results. When there are sufficient data like in Week 5-7 and World Championship, I use historical World OPR and highest OPR. I also use the OPR calculated in real time for that event. Using one of them, I predict the rest of the matches and predict the final ranking. It is useful to have some idea ahead of time.
Please don't call me Mr. Ed, I am not a talking horse.
Unread 13-03-2013, 17:32
MisterG's Avatar
MisterG MisterG is offline
Think twice post once.
AKA: Alan Gilgenbach
FRC #2062 (C.O.R.E. - Community of Robotics Engineers)
Team Role: Team Spirit / Cheering
MisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to all
Great work as usual, very helpful data.
Does anyone have an update on when Northern Lights data may be available?
Lots of teams from NL are coming to WI next week.
Alan Gilgenbach
C.O.R.E 2062
Unread 14-03-2013, 01:16
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
Here's an interesting result: 294 has an OPR of 18.4 at the Central Valley. Yet it had no shooter so no auto or teleop points, and it couldn't hang. It had very strong defense (which put it very high on our #3 draft list--we picked 295, a strong defender as well instead). So something weird is happening the OPR if a team with no apparent offense is doing this well. Looks like the OPR this year is capturing defensive efforts as well.
Unread 14-03-2013, 03:09
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
All data is alliance wide, not robot specific.
This is why you can't rely on OPR as your only source of data.
2001-2004: Team 100
2006-Present: Team 254
Unread 14-03-2013, 03:18
AdamHeard's Avatar
Lead Mentor
They didn't score much, but they did score. We had them averaging .2 in auto with a max of 2, and 1.64 frisbees in teleop with a max of 4.
Unread 14-03-2013, 03:35
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
When will Israel's rankings be updated?
Team FRC#2212 The Spikes, 2011-...
Builld leader 2013
Drive coach 2012-2013
Mentor 2015-...
Unread 14-03-2013, 08:52
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
(bolded for emphasis)
I don't follow your logic. Teams that score points by drawing fouls are still teams that score points, and points = offense.
Hi!
