Go to Post The MAINTENANCE of teams is just as important as the growth. Starting a new team is not always the answer. - Amanda Morrison [more]
Unread 12-03-2013, 08:29
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Is a frisbee as a robot part legal?
We have a hopper with a flat, aluminum bottom to bring our frisbees up to our shooter (Here is a picture of the robot). the frisbees stack on top of each other, which means that with a full load of four frisbees, the first three come off from on top of another frisbee. Those three are all accurate. The fourth comes off the flat aluminum sheet at the bottom of the hopper, which causes it to go into the shooter faster, and miss high. We were wondering if it would be legal to cut up/cut holes in one of our practice frisbees, and bolt or rivet it to the bottom of the hopper, on top of the aluminum plate. therefore making the surface from which each frisbee comes from equal.
In short- can we install game pieces on the robot without failing inspection?
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 12-03-2013, 08:40
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: Is a frisbee as a robot part legal?
I don't think you will have a problem during inspection, but you do stand a chance of a referee mistaking the frisbee that is part of your robot as being one of the four you can control during teleop.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 12-03-2013, 08:41
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
You could always spray paint it so it is not confusing.
Unread 12-03-2013, 08:42
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
It's a COTS item and anyone can purchase it. Assuming you are below the weight limit you are good to go. I agree with rsisk, I would consider painting the disc before installation to avoid any potential confusion.
Unread 12-03-2013, 08:48
Originally Posted by jwfoss View Post
Its a COTS item and anyone can purchase it. Assuming you are below the weight limit you are good to go. I agree with rsisk, I would consider painting the disc before installation to avoid any potential confusion.
Ok, we'll probably speed-hole it, too, to avoid confusion.
Thanks!
Unread 12-03-2013, 09:10
Carol's Avatar
Carol Carol is offline
FRC #0365 (MOE)
Carol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond repute
From the Q&A - Q501
Q. Can I attach a disc (that has been painted) to my robot as a permenant part of the robot design and function?
2013-02-16 by FRC1885
A. There are no Rules prohibiting this.
MOE 2007 Chairman's Video by MOE video team and Paul Lazarus http://moe365.org/CHMN_AWD_video_2008.php
MOE 10-Year Video Celebration on YouTube http://www.youtube.com/watch?v=ETcSMUBUqEs
Unread 12-03-2013, 09:31
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Originally Posted by Carol View Post
From the Q&A - Q501
As an inspector, I would have no problem with a disc being part of your robot. Just be forewarned that another inspector may question it, so I would recommend having a print out of the above referenced Q&A item (from the Q&A web page, not from CD) handy. Make sure to paint it some color besides red, white, or blue, as even with holes in it, with the speed things move on the field it could be hard for the referees to keep track of it otherwise. And you want to make sure that other teams will not have a reason to be asking if your robot was holding 5 discs at times during the match.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 12-03-2013, 14:11
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
2809 had a red frisbee on their robot, it looked like a frisbee guide. If you are only shooting white frisbees, a red or blue frisbee shouldn't be a point of confusion for the referees.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 12-03-2013, 14:37
pfreivald's Avatar
AKA: Patrick Freivald
And yet, "shouldn't" isn't "isn't"!
I'd recommend painting it, too...
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 12-03-2013, 14:40
Gregor's Avatar
Agreed, no harm in making it more obvious.
<Since 2011
Unread 12-03-2013, 14:50
nocapitals's Avatar
nocapitals nocapitals is offline
FRC #3539 (The Byting Bulldogs)
nocapitals is an unknown quantity at this point
This is slightly different, but last year, our team used a basketball net as part of our robot. It passed inspection every time, they even mentioned it as a creative use of field elements in one of our awards.
I had this dream last night! I joined a robotics team and...oh god...
Unread 12-03-2013, 14:58
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Then there are the teams that used part of the kit totes as robot parts. Anything in the kit is fair game.
Painting could be an issue if it changes the surface properties too much.
Unread 12-03-2013, 15:56
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
If you cut two Frisbee in the same way you could swap out pieces to have it easy to see it is not an actual Frisbee.
