Go to Post Logic has no place here whatsoever. - ThamiorLianodel [more]
Unread 12-03-2013, 16:21
TRWSHSHLX TRWSHSHLX is offline
AKA: Henry Lei
TRWSHSHLX is an unknown quantity at this point
Re: [FTC]: Limit switch
For the first question: I'm not sure about the legality of directly connecting a limit switch inline from the DC controller to the motor. However if that is the implementation, the DC motor won't be able to move for the rest of the match (since the limit switch stays "activated" and there's no way to un-activate the swtich).
As for the second question, it depends on how the limit switch is programmed in your code. If the code is like:
If (Limit_Switch is on)
Motor off
Else
Custom controlling code
Then it will shut off for sure since no matter the condition of Wifi because when the limit switch is on then it doesn't matter what the joystick command is.
Unread 13-03-2013, 07:37
Beyond Infinity Beyond Infinity is offline
Beyond Infinity is an unknown quantity at this point
"As for the second question, it depends on how the limit switch is programmed in your code. If the code is like:
Motor off
Else
Then it will shut off for sure since no matter the condition of Wifi because when the limit switch is on then it doesn't matter what the joystick command is.[/quote]"
Thanks for the reply !!! If we use a touch sensor is it possible to make the motor stop working only in one direction ? What would be the algorithim to do so(without interfering with the joystick commands) ?
