Go to Post I guess this means we have to work on becoming super-flexible and always be ready for our close-ups at robotics from now on? - Beth Sweet [more]
Unread 11-03-2013, 17:53
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
Xbox Controller Tank Drive
Hello. My team would like to use a tank drive system to drive our robot. I know how to do it with two joysticks but not 1 joystick that is an xbox controller. Can anyone help? Thanks!
Unread 11-03-2013, 18:59
tp2357 tp2357 is offline
AKA: Tyler Pawlaczyk
FRC #0340 (Greater Rochester Robotics)
tp2357 is an unknown quantity at this point
Re: Xbox Controller Tank Drive
Instantiate the controller as a joystick.
The different physical stick on the controller are different axis to the code. You'll have to hack a bit/google to figure it out, I can't remember off the top of my head. The triggers are also another axis, with one pulling it negative, and the other pulling it positive.
I hope this helps.
Java, Embedded C and LISP.
Unread 12-03-2013, 10:46
JefferMC JefferMC is offline
AKA: Jeff Corbett
FRC #1319 (Flash)
JefferMC will become famous soon enough
As tp said, you can treat the XBox controller as a very strange joystick that has 6 different axes:
1 Left Joystick X
2 Left Joystick Y
3 Triggers
4 Right Joystick X
5 Right Joystick Y
6 DPAD X (never used this)
So, do joystick.GetRawAxis(2) for the left tank drive and joystick.GetRawAxis(5) for the right. You may need to change the signs of the input to get what you want.
Unread 12-03-2013, 13:08
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
Here is our XBOX Class
Here is our TankDrive Command
We init an XboxController object in the OI, and I have everything mapped out in the class for the axis. Makes it very simple to call from commands.
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 12-03-2013, 13:59
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Go to run on your computer (if you're using Windows) and search for / run "joy.cpl" (without quotes). Then go to properties (I think) and it should show you everything you could ever need to know about mapping the controller.
Unread 12-03-2013, 18:10
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
Ok thanks guys ill try that
Unread 14-03-2013, 21:36
AlexBrinister AlexBrinister is offline
AKA: Alex Brinister
FRC #1768 (RoboChiefs)
AlexBrinister will become famous soon enough
We used one too! You can look at this code. It's in C++ but the WPI syntax should be similar.
Alex Brinister
