Go to Post You only really ever need 2 things in your tool box: A Hammer to separate things that shouldn't be together, and Duct Tape to put things together that shouldn't be apart. - Dave_222 [more]
Unread 12-03-2013, 19:27
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Quick request - screenshot of driverstationIO
Just a quick request since I don't have access to our classmate/anything with DriverStation on it. Could someone post a screenshot of the simple IO on DriverStation, I just want to make sure I remember which way its sorted. (the buttons)
All opinions are my own.
Unread 12-03-2013, 19:35
Re: Quick request - screenshot of driverstationIO
Did you look at the documentation? http://wpilib.screenstepslive.com/s/...ation-software
Unread 12-03-2013, 19:36
AKA: Joel Gallant
Wow, didn't realize screensteplive also did the Driverstation stuff. Thanks.
Unread 12-03-2013, 19:38
AKA: Joel Gallant
I assume that I would use DriverStationEnhancedIO.getDigital(port) to check the state of the "Digital Inputs" here?
Unread 12-03-2013, 20:28
That image shows the Compatible IO which is what can be set on the PC using the mouse if desired. To get the values, use DriverStation.getDigitalIn(channel)
Unread 12-03-2013, 20:44
AKA: Joel Gallant
Thanks.
Unread 17-03-2013, 12:49
java4first java4first is offline
(Java) Programming Mentor
AKA: Stu
FRC #0501 (Power Knights)
java4first is an unknown quantity at this point
We are trying to use this (for both digital and the 4 analog inputs). However, you only get a value when the robot enables in a mode - otherwise no matter how you move the sliders, and the GUI updates, it stays the same when calling the get methods with an index on the drivers station. I could swear in previous years, it would update. I have used the 'check' methods, and am getting both driver station updates and new control data (which looking down in the WPILib code, would appear to be where this comes in).
Is anyone else having this problem? Or is it supposed to work this way, and my memory is wrong ...
Thanks in advance!
