Go to Post Nutritionally speaking I didn't get enough (MOE) green in my FIRST diet this year! - Mark McLeod [more]
Unread 10-02-2013, 17:34
bang-bang control with Talon
I'd like to know of any teams which have successfully used Talon motor controller for shooter-wheel bang-bang speed control. Thanks.
Unread 10-02-2013, 19:40
Re: bang-bang control with Talon
We did it. But it's not going to be on our competition robot.
We put a strip chart on the Dashboard to display the RPM as measured by the encoder. Our programming students decided they weren't satisfied by the amount of overshoot it showed, and implemented a simple PID controller. A few minutes of tuning later (plus some tweaking of the algorithm to limit integral windup), it works great.
The continual loud snaps and clicks from the gearbox when using bang-bang were rather disturbing to most people hearing them. The simple PID sounds smooth as silk, appears to bring the motor up to speed just as fast, and recovers quickly from a brief additional load without problem.
Unread 10-02-2013, 19:46
Did you get the same disconcerting results with a Victor?
Unread 10-02-2013, 19:56
AdamHeard's Avatar
Lead Mentor
Very impressive it the performance is truly comparable.
Are you doing PID on velocity itself?
Is it output = PID, or output += PID?
Are you using all three terms?
Are you limiting the motor to never allow a negative power applied?
Unread 10-02-2013, 20:34
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
We did on our prototype shooter. We had no problems direct driving AM pneumatic wheels with CIMS from the Talons.
The final robot uses Victors for controlling the shooter, as excellent linearity is not needed for bang-bang control.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 10-02-2013, 20:48
Red face Re: bang-bang control with Talon
Oops.
The programming group is using a drivebase built out of the Kit chassis this year. Its drive wheels are controlled using Talons, and the actual robot has Talons installed for the shooter motors, and that's what I was thinking of when I answered the question.
However, the shooter test rig on the Kit 'bot was wired up using Victors. I'm sorry for the bad data.
Both the setpoint and process variables are in values of "kRPM".
After we discussed the fine points of position vs. velocity control, I believe the student doing the programming chose to send the output of the PID computation directly to the motor rather than doing a post-PID integration. I was busy with other tasks while he was tuning it, but I'm pretty sure the D constant ended up being zero, and the P constant is probably negligibly small. Most of it is I, as one would expect from a velocity PID.
The output is indeed limited to never apply power the motor in the "wrong" direction. There is a use case where the shooter motors must be run in reverse, so the control software keeps the output either positive or negative as appropriate, based on the polarity of the desired velocity.
Unread 12-03-2013, 22:21
xmaams xmaams is offline
AKA: Sam Dietrich
FRC #2587 (Discobots)
xmaams will become famous soon enoughxmaams will become famous soon enough
We are using bang-bang control on Talons with two 4-7/8" wheels (I think).
We painted half the wheel white and used a light sensor to measure rpm. All of our shots went in at Lone Star when we positioned our robot correctly.
Unread 12-03-2013, 23:15
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Would a spike relay have a snowball's chance of reacting quickly enough for a bang-bang controller?
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 12-03-2013, 23:19
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Even if it could, I wouldn't feel comfortable having it switch that fast. Remember, it's a mechanical relay. Something is actually moving in there.
Unread 12-03-2013, 23:28
Woolly's Avatar
Programming Mentor
Well drat. There needs to be a tiny FRC-legal motor controller that does full-backward, stop, and full-forward only.
Unread 13-03-2013, 08:04
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We found the same. The bang-bang sounded horrible, and had a bit of a sine wave on our graphs. This was probably a result of an update time that was too slow. It was easier to review our code from last year and implement something similar. We don't even have to retune it from practice to comp bot.
Unread 13-03-2013, 17:01
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Slow loop timing could easily cause both overshoots and undershoots.
Additionally, one of our local teams used a slightly modified Bang-Bang to resolve the "The bang-bang sounded horrible" issue. What they did was increase the "off" state drive from "0" to 30% power.
They also added a second case to completely stop the motor when not needed.
Unread 13-03-2013, 23:23
AKA: Sam Dietrich
We had a lot of this at first. When we set up bang-bang on our shooter, our encoder outputs were jumping around by about 300 rpm, and even with direct drive off a miniCIM, bang-bang didn't sound very good.
Eventually we convinced the rpm function of the counter class to use the FPGA timer, and the numbers settled down very well.
Then by having the code attempt to update the Talon output every millisecond we eliminated almost all of the overshoot and variation. It is changing state so quickly now that the motors sound just as smooth as ones receiving constant PWM.
