Go to Post P.S. While I doubt Karthik's "Delgado" jersey would go for $500,000... it would be much cooler to see Carlos Degado wearing a "Kanagasabapathy" jersey. THAT I might pay for! - dtengineering [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 12-03-2013, 23:09
josh.pruim josh.pruim is offline
FRC #4014
josh.pruim will become famous soon enough
FRC FMS Questions
Does anyone, by any chance, know very much about the FRC's FMS hardware/software setup? I was going to work with some other local teams to try to build a practice field with a FMS-like interface. I can't seem to find the Driver Station source code (I have found dashboard code but no DS code, Did I just forget to install it?)
When in doubt, CAD it out!
Better is what is plus one.
Unread 12-03-2013, 23:20
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: FRC FMS Questions
The FMS white paper is probably your best place to start.
http://www.usfirst.org/sites/default...Paper_RevA.pdf
Also this page has a download for FMS Lite, it hasn't been updated since 2009 but it's the best that has been released as far as I know.
http://www.usfirst.org/roboticsprogr...control-system
Unread 12-03-2013, 23:23
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
There is also FMS Delta - something I'm not familiar with, but I heard that it was used at MadTown Throwdown last fall.
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
The Driver Station source code is not published.
If you want something FMS-ish, search for "FMS Lite" (or "FMS Light"). It was released for the 2009 season, and updated slightly for 2010.
Unread 12-03-2013, 23:32
FRC #4014
The FMSLight download appears not to work, I get a 404 with it, but the diagram helps make some sense of it. Any other resources anyone else knows of?
Unread 12-03-2013, 23:58
FRC #4014
I know you can rent the field http://www.andymark.com/product-p/offseasonfield.htm, but, it's in Indiana, which, at the $2/mile, getting it to the San Diego area could be a bit expensive. so the idea is to build a FMS-like system for local events that could be loaned out to teams in the area for use.
Unread 13-03-2013, 00:33
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
There is no published source code for the DS that is public, and I doubt it would be since it is IP. FMS also will not be released to the public. FMS Lite is the closest you will get to run a field without renting one (with an FTA) from FIRST or AndyMark for each event.
-Michael Dessingue
Unread 13-03-2013, 09:52
Racer26 Racer26 is offline
There also used to be FMS Delta, which in my mind was much more useful than FMS Light.
It was the Full FMS, minus some of the VLANing features that the real FMS uses to keep my robot from doing things to yours.
I found an old word document Mark posted on team358.org, but the links to download FMS Delta in it (from port 81 on an IP address starting with 208), no longer work.
Unread 13-03-2013, 14:59
FRC #4014
I'm working on a project called OpenFMS which will be similar to the real FMS including VLANing. It's currently in beta and very buggy. https://github.com/itguy51/FRC-OpenFMS
Unread 13-03-2013, 15:42
Andrew Lobos Andrew Lobos is offline
FRC #0225 (TechFire)
Andrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the rough
For the networking side of the FMS, you might find this interesting: http://www.chiefdelphi.com/media/papers/2266
Last year, I used that white paper to build a simple Java app that sends FMS packets to a 2012 driver station. I didn't really pursue it that much after I got basic control working. I got it to the point where the DS would go "FMS Connected" and be able to have the robot state + alliance station set.
Here is my implementation: https://github.com/4ndr3w/Java-FRC-FMS
Unread 13-03-2013, 19:35
FRC #4014
4ndr3w - your code is actually what I'm using for main library functions. It was the only current FMS library I could find. The idea is to have a java service communicate with a c# UI to gain access to Windows screen functions.
Unread 14-03-2013, 01:15
FRC #4014
I've just updated OpenFMS to have a non-blocking GUI, disable checkboxes, and a timer along with a progress bar. I hope to add a Display Screen that shows scores and match time, and eventually add a layer for communication with Arduino devices for E-Stop buttons. Those whitepapers are very descriptive, and they helped me better understand the packets themselves.
Unread 14-03-2013, 16:00
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
If either of you guys want a hand with development, I'd love to join in.
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Unread 14-03-2013, 18:13
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Id be willing to help too if needed. I have a decent knowledge of C#, so if you want to get it working in C# id be willing to help.
Team 4488 - Mentor 2013-2016
Unread 14-03-2013, 20:23
FRC #4014
The Java code is on Github, and is open for development by anyone that wants to poke around with it. https://github.com/itguy51/FRC-OpenFMS
As a side project, I'm going to see if I can make a version that creates a hotspot on my phone and can act as a lightweight FMS in my back pocket.
