Go to Post FIRST isn't for wimps. It never has been. - JaneYoung [more]
Unread 13-03-2013, 04:47
CardcaptorRLH85's Avatar
CardcaptorRLH85 CardcaptorRLH85 is offline
The master of the cards ^_^
AKA: Raa'Shaun H.
FRC #0322 (F.I.R.E. "Flint Inspires Real Engineers")
CardcaptorRLH85 is an unknown quantity at this point
Send a message via ICQ to CardcaptorRLH85 Send a message via AIM to CardcaptorRLH85 Send a message via MSN to CardcaptorRLH85 Send a message via Yahoo to CardcaptorRLH85
Question SmartDashboard with CommandBasedRobot Template
Since all of the tweaking of our robot code with regards to its proper operation are done, I've been working on customizing the dashboard using SmartDashboard. However, as I'm using the CommandBasedRobot template, I've run into a puzzling issue. I have no idea where to put all of my SmartDashboard:utNumber... commands.
I've come up with three ideas, and reasons why each of them may not work properly.
1) Place the SmartDashboard output commands in the Subsystem functions that access the required objects.
Problem: I end up with SmartDashboard code everywhere and that seems a bit messy.
2) Create a SmartDashboardOutput Command. (This is what I was doing before posting this topic.)
Problem: It 'Requires' every Subsystem that I want output from and I'm worried that those requirements (and the interrupts that they will cause) will stop the robot from functioning correctly.
3) Put copies of all the SmartDashboard commands in the appropriate functions (DisabledPeriodic, AutonomousPeriodic, and TeleopPeriodic) of the CommandBasedRobot.cpp file.
Problem: This seems to make the most sense but I'm not sure that this is where these things should go. Also, I'd end up with three copies of each output line.
I've read the SmartDashboard guide but all of its code examples seem to use the SimpleRobot template so I haven't been able to use that as a reference for this purpose.
Normally, if I couldn't figure something like this out, I'd just write it all three ways and test by trial-and-error but, we only have so many 'Robot Access Period' hours before this weekend and I'd rather not waste any driver practice time with unnecessary flashing.
Thanks for any help you can provide ^_^
Unread 13-03-2013, 09:34
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant future
Re: SmartDashboard with CommandBasedRobot Template
We created a function to hold all the SmartDashboard calls in the robot class. It is hooked to a GetRawButton on the joystick inside each of the appropriate functions. That way we aren't sending all the data when we don't have to have it.
Unread 13-03-2013, 15:45
AlexBrinister AlexBrinister is offline
AKA: Alex Brinister
FRC #1768 (RoboChiefs)
AlexBrinister will become famous soon enough
We just have it in our TeleopPeriodic() loop running at whatever interval we set it to from the Dashboard. Personally, I would just make a function and put it in a vxWorks task instead of thinking about it too hard. But then again, that would defeat the purpose of Command-based robot, which is to eliminate any reason why you would worry about relatively complex things like threading.
Alex Brinister
Unread 13-03-2013, 16:33
BigJ BigJ is online now
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
You don't have to "require" the subsystems. If all you are doing is reading from them, it is fine. Because the Command extends CommandBase, you have access to the subsystem. the only thing that requires() does is stop other commands that require the subsystem because you are ostensibly going to affect the subsystems outputs.
TL;DR: If you are using a subsystem as read-only it is probably safe not to require it, AFAIK.
Unread 13-03-2013, 16:37
AKA: Raa'Shaun H.
Really? If that's true then I should be good. Thanks ^_^
Unread 13-03-2013, 20:53
AKA: Jeff Clements
I have not been able to get commands to run in disabled. If you are able to, I'd like to know how.
Unread 13-03-2013, 21:27
In Java, there is a setRunWhileDisabled method, that you can call in the constructor of the command. You also need to call the scheduler in the disabledPeriodic. I assume it's similar in C++.
Unread 13-03-2013, 21:40
AKA: Jeff Clements
Ah. Probably. I was running the scheduler, but didnt know about the setRunWhileDisabled option. I'll check it out tonight.
Thanks
Unread 13-03-2013, 21:42
AKA: Raa'Shaun H.
Yup, in C++ it works like this:
	virtual void RobotInit() {
		CommandBase::init();
		lw = LiveWindow::GetInstance();
                RandomCommand->SetRunWhenDisabled(true);
	virtual void DisabledPeriodic() {
		RandomCommand->Run();
		Scheduler::GetInstance()->Run();
