Go to Post I'm sure they liked the size and power output but disliked when they were on fire. - notmattlythgoe [more]
Unread 13-03-2013, 21:54
Negative 9 Negative 9 is offline
FRC #0611
Negative 9 is an unknown quantity at this point
Is it necessary to have the 2013 Image for the Driver Station?
At the competition, is it necessary to use the 2013 Image for the classmate? Or can we just use the 2012 image?
Unread 13-03-2013, 21:58
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Is it necessary to have the 2013 Image for the Driver Station?
It's not necessary at all.
All opinions are my own.
Unread 13-03-2013, 22:00
The Classmate image doesn't matter, but you do need a Driver Station software version of at least 1.29.13.00 which requires the LabVIEW 2012 Runtime. If you want an image in the Dashboard you will need Vision 2012 as well. If you have not already updated the DS software from last year, it may be faster to re-image then to uninstall the LabVIEW 2011 components and install the LabVIEW 2012 stuff.
Unread 13-03-2013, 22:18
ablatner ablatner is offline
AKA: Andrew Blatner
FRC #0100 (The Wildhats)
ablatner is on a distinguished road
While it might not be necessary, in general it's best to keep ALL your software up-to-date.
Unread 14-03-2013, 00:17
FRC #0611
How do I tell what version my Driver Station software is?
EDIT: When I mouseover "Driver Station.exe" in the program files, it says the File Version is 4.0.0.14
I assume that means we're fine even though we're still running the 2012 DS image, right?
Unread 14-03-2013, 00:39
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
Open your Driver Station software and go to the [I think] "Setup" tab. It should tell you version number.
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 14-03-2013, 14:44
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
If you mean can you compete with the same software that you used last year then the answer is no. If you have not installed the new DriverStation software this season (including the update released after kickoff) then this definitely must be done in order to compete. But it is not necessarily required to install a whole new image on the Classmate, just installing the new software is sufficient.
Unread 23-03-2013, 23:03
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
http://wpilib.screenstepslive.com/s/...ation-software has images of the driver station tabs.
Callout 5 on the Diagnostics tab shows where the DS version is on this tab.
You must have the DS version 1.29.13.00 or newer to compete.
