Go to Post I suggest that you don't discuss...sensitive issues about your team on this public forum. - Andy Baker [more]
Unread 13-03-2013, 14:22
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
How does your team charge & test batteries?
I have seen a few teams with some elaborate battery stations but I am looking for an inexpensive way to ensure that our batteries are fully charged before each match.
Recently I bought a Wel-Bilt 125 Amp battery load tester from Northern Tool but not sure how well this will fit the bill.
Anyone with experience with this tester or with helpful suggestions is appreciated.
Thanks and Best wishes to your teams at the competitions...
Unread 13-03-2013, 14:24
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Re: How does your team charge & test batteries?
As a preseason project, we made a batter charging station. it is on wheels and painted our team's colours. It can charge 12 batteries at once and is nicely organized.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 13-03-2013, 14:40
mschwab013's Avatar
mschwab013 mschwab013 is offline
AKA: Matt Schwabenbauer
FRC #0291
mschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to all
We just use the load tester you bought to test batteries preseason. During competition we a Fluke voltmeter to check how charged the battery is. As for a system of charging batteries, we label each battery a letter. Starting with A we use them sequentially for each match. This seems to work for us because the battery we use next is the one that has been charging the longest and theoretically should have the best charge. I hope this helps!
2013 Pittsburgh- Gracious Professionalism award, 7th seed, 6th alliance captian, quarter-finalist(291,3492,4601)
2013 Queen CIty- Chairman's Award, 39th seed
2012 Pittsburgh- 23rd seed
2012 Buckeye- 34th seed, 2nd alliance, quarter-finalist(291,1241,4085)
2011 Pittsburgh- 13th seed, 5th alliance, quarter-finalist(291,337,3504)
2011 Buckeye- 18th seed, 8th alliance, quarter-finalist(279,291,3496)
2010 Finger Lakes- 15th seed, 5th alliance, quarter-finalist(291,1507,1559)
2010 Buckeye- Chairman's Award, Imagery Award, Quality Award, 4th seed, 1st pick, 1st alliance, semi-finalist(291,1014,1629)
Unread 13-03-2013, 14:45
Buy a Battery Beak!!! Such a great product! I sound like an infomercial but after using one of these things I will never need anything else for batteries.
http://www.crosstheroadelectronics.com/Beak.html
Unread 13-03-2013, 14:58
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
We use the battery beak during competition. Full charge is 115% or above. In the off season we perform a capacity check on the batteries to ensure they are still useable.
We also built a 9-battery charging station using the tripple battery chargers from Andymark. They are much better than the charger FIRST supplies with the KOP.
Unread 13-03-2013, 15:02
blackbirdfan blackbirdfan is offline
FRC #1706
blackbirdfan is an unknown quantity at this point
Our battery charging station uses 2 4-bank battery chargers (http://tinyurl.com/a95lyts) to charge our batteries. It can probably hold 12 batteries, but we only have 8 good ones which is why we bought two 4-bank chargers. The chargers have led lights that are supposed to represent the charging state of each battery, and they seem pretty reliable, but we just use a standard multimeter to test batteries. That Wel-bilt tester seems like it would work fine, but it doesn't seem to do anything that a multimeter couldn't. Anyways hope this helped!
Unread 13-03-2013, 15:18
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
The only thing a multimeter will tell you is voltage. You can charge a battery that is shot to 13V, but it could drop out on you 15s into the match. A multimeter won't catch that.
2001-2004: Team 100
2006-Present: Team 254
Unread 13-03-2013, 15:24
coalhot's Avatar
coalhot coalhot is offline
Assistant to the regional manager
AKA: Phil
FRC #4454 (Artisan Rockets)
coalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant future
Send a message via AIM to coalhot
This. I accidentally put a battery just like this in our robot in 2009, went from 13 to 7 volts after the match started (the battery had been killed by trying to test a motor that was shorted, and happened to find a way into the rotation of good ones).
You can ask Akash, we were allied with 11 in that match. There's nothing worse than losing a match because of an error.
Edit: I wish I had a battery beak, it would have prevented the mistake from ever happening. Reason being that the battery beak puts a load on the battery, so if it's actually dead, the beak will show it. Best. Tool. Ever. Wish they existed in '09
Current home, 4454 (Glowa's ghetto Philly FRC team). Check us out!
My posts represent my personal views only, and do not represent the views of my team, its school, sponsors, or FIRST.
Unread 13-03-2013, 15:35
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Using a multimeter to check the voltage of a battery is only accurate to know the charge status of a battery, not whether it is "healthy" or not. Some batteries may appear to be fine after checking the voltage but will not be able to provide high current draw without significant voltage drops.
Load testers will give a more accurate assessment of the health of a battery.
Art Dutra IV
世上无难事,只怕有心人.
Unread 13-03-2013, 16:44
Japper,
I would recommend against the use of the device you list. It is intended for batteries with a much higher capacity/peak current. Continued use of this device is likely to shorten your battery life.
The use of the West Mountain Radio CBA III or the Battery Beak is a much better choice for FRC batteries. The CBA will allow you to test the battery the same way method as used by the manufacturer and the Battery Beak is a simple, pocket tool to give a good indication of battery health.
As pointed out above, a voltmeter tells you nothing other than a cell is shorted of the battery is open.
Unread 13-03-2013, 18:04
The Wel-Bilt 125amp tester doesn't look like it's intended to be used like the CBA (i.e. hooked up to the battery and left for a period of time discharging the battery).
It's more like the Battery Beak, only with a much higher load.
Is a 125 amp load applied to the battery for 5 seconds once or twice a year going to harm the battery?
* @ Japper: can you post a pic of the user instructions for this product? I couldn't find them online.
Unread 14-03-2013, 04:05
Japper's Avatar
Do you use it to test Cold cranking amps (CCA) and a start test or do you just connect it to
a battery to measure the voltage under a load?
If you are testing CCA what are you setting the CCA value to?
Not a bad tester for $24 (on sale)...but I had to upgrade mine with a pair of anderson connectors
beween the unit and the clamps...
thanks
Unread 14-03-2013, 07:57
Japper's Avatar
I scanned the instruction manual in and attached it to this post...
thanks
Unread 14-03-2013, 09:16
Ether,
The sheet is hard to interpret but the specs state CCA of 200-1000 CCA. Each test lasts 5 seconds. If the tester is in the 200 amp setting it might be OK for our batteries but we rarely will draw current for that length of time. My general rule of thumb is always to submit the battery to the least amount of shock. This type of tester will ultimately lead to decreased life in my opinion.
Unread 14-03-2013, 10:17
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
I don't know all the specifics but 955 built a 4 battery cart with a custom board that drains batteries all the way before charging them again to ensure maximum charge. Probably too much to do before competition as it took them 3 years
