Go to Post Keep reading. - Billfred [more]
Unread 14-03-2013, 15:03
Mr.Roboto3335's Avatar
Mr.Roboto3335 Mr.Roboto3335 is offline
Wait, What?
AKA: Jimmy
FRC #3335 (Cy-Borgs)
Mr.Roboto3335 is an unknown quantity at this point
Controlling motor speed with joystick scroll
I just wanted to know how to program the motors to where the speed changes depending on the value of the scroll on the Logitech Attack 3 Joystick.
Wait, what?
Unread 14-03-2013, 15:09
Re: Controlling motor speed with joystick scroll
Are you talking about drivetrain motors or something else?
Unread 14-03-2013, 16:04
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
- read the value of that axis (Axis 3 I think)
- convert it to a number between 0 and 1 (y=mx+b, yay algebra)
- Multiply your other joystick inputs by this number (or your motor outputs)
It may not be useful to have the bottom of the throttle act as 0. Maybe make it 20% (0.2 to 1 is now the output of y=mx+b)
let's look at how this works. At full throttle, and max joystick input, the motor will get (joystick * throttle) = (1 * 1) = 1
If you bring the throttle back to 50% (0.5), then the motor gets (1 * 0.5) = 0.5, which is half speed.
Unread 14-03-2013, 17:01
Wait, What?
AKA: Jimmy
2 Shooter motors.
Wait, what?
Unread 14-03-2013, 18:15
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
I reccomend against doing something like that. 4183 tried it for our first regional last year and learned that it was nearly impossible to get fine control of our shooter speed due to the slop in the throttle. Before our second competition, we programmed the joysticks to control rate of change in speed rather than speed.
It's pretty simple code to write:
If speed-up button is pressed, shooter speed = shooter speed + constant
If speed-down button is pressed, shooter speed = shooter speed - constant
Other buttons can be used to stop the shooter or run it at preset speeds.
However, if your shooter works consistently at a range of speeds, the throttle might work fine.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 14-03-2013, 19:28
AlexBrinister AlexBrinister is offline
AKA: Alex Brinister
FRC #1768 (RoboChiefs)
AlexBrinister will become famous soon enough
If you really want to do that, you don't need to do algebra because WPI does it for us already. All the axes read from 1 to -1. So you should be able to just give the motors the axis and they should behave accordingly.
Alex Brinister
Unread 14-03-2013, 20:19
Custom User Title
AKA: Cal
Alex Brinister
You don't want to run your shooter in reverse and you want to be able to get maximum resolution by using the throttle's full range of travel.
Unread 14-03-2013, 21:30
AKA: Alex Brinister
Touché .
Alex Brinister
