Go to Post Attempted to like Andrew's comment and then realized this wasn't Facebook :P - afowl [more]
Unread 14-03-2013, 18:56
flamer075 flamer075 is offline
FRC #3200
flamer075 is an unknown quantity at this point
Re: Feeding into shooter
Originally Posted by Matt704 View Post
We use a 5 gallon bucket with a slot on one side just big enough for a frisbee to fit through and then a pneumatic piston mounted under the shooter to push the frisbees through.
What is to prevent the frisbee from landing on top of the pneumatic?
Unread 14-03-2013, 19:31
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
We are using what sounds like a similar system. For us, the Frisbee right above the one being pushed does fall on top of the piston's pushing part, but a ramp on the return side of the pusher allows the piston to return without interference from the frisbee.
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
Unread 14-03-2013, 20:30
FRC #3200
Do you have a picture?
Unread 14-03-2013, 21:12
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
We took a minibot gear and drilled out a hole offset from the center. Then we attached the pg71 gearmotor to it in that hole and it pushes frisbees in quickly and consistently, no pneumatics necessary.
Unread 14-03-2013, 22:05
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
Team 67 did something similar to this. They attached paddles on a chain and powered it to push the frisbees into the shooter at a constant interval.
As for 308 we used a pneumatic cylinder.
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
