Go to Post At the end of the day, and this is where many may disagree, it's about what is learnt and not about who wins. - popnbrown [more]
Unread 14-03-2013, 11:39
flamer075 flamer075 is offline
FRC #3200
flamer075 is an unknown quantity at this point
Feeding into shooter
My team is using a stacking idea for our hopper, but we have yet to come up with a way to feed the frisbees into the shooter. We don't know how we can push a frisbee into the shooter with out the other frisbee getting caught on top of the device that would feed the frisbee into the shooter. So how are your teams feeding into your shooter? Thanks for any help.
Unread 14-03-2013, 11:45
viveksridhar viveksridhar is offline
FRC #2367
viveksridhar is an unknown quantity at this point
Re: Feeding into shooter
We're using an arm made of metal attached to a window motor to push our frisbees out of the hopper into the shooter.
Since the arm is made of one piece of metal, it's smooth and thin enough so that it doesn't get caught on the frisbees stacked on top. Assuming you have the height of the arm at the right level, and the arm is smooth, then you shouldn't have any issues with frisbees getting caught.
Another option is using a piston (if you're comfortable with pneumatics), and attaching a small plate to the end of the piston. This has more of a chance of getting caught though, on the retracting stroke of the piston (under the edge of the frisbee right above it).
Unread 14-03-2013, 11:59
Matt704's Avatar
Matt704 Matt704 is offline
AKA: Matt Ricks
FRC #0704 (Warriors)
Team Role: Driver
Matt704 is on a distinguished road
We use a 5 gallon bucket with a slot on one side just big enough for a frisbee to fit through and then a pneumatic piston mounted under the shooter to push the frisbees through.
Visit our You tube channel http://www.youtube.com/user/SGPHSRobotics
Team 704 warriors
2012 Dean's List Winner
2011 Dean's List Finalist
2010 Dean"s List Finalist
Unread 14-03-2013, 12:05
Lisam Lisam is offline
FRC #2013
Lisam is an unknown quantity at this point
Our Shooter has two servos. One on the front(wheel side) that lifts the stack other than the bottom one and the second pushes the bottom Frisbee into the wheel.
Unread 14-03-2013, 18:56
FRC #3200
What is to prevent the frisbee from landing on top of the pneumatic?
Unread 14-03-2013, 19:07
markmcgary's Avatar
markmcgary markmcgary is offline
Software Mentor
FRC #4322 (Clockwork Oranges)
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
That sounds much like the Team 4322 system. The reveal video has a nice closeup of the piston mechanism in action. It has worked flawlessly so far.
Unread 14-03-2013, 19:31
Ankit S.'s Avatar
Happy Birthday! Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
We are using what sounds like a similar system. For us, the Frisbee right above the one being pushed does fall on top of the piston's pushing part, but a ramp on the return side of the pusher allows the piston to return without interference from the frisbee.
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
Unread 14-03-2013, 20:30
FRC #3200
Do you have a picture?
Unread 14-03-2013, 21:12
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
We took a minibot gear and drilled out a hole offset from the center. Then we attached the pg71 gearmotor to it in that hole and it pushes frisbees in quickly and consistently, no pneumatics necessary.
Unread 14-03-2013, 22:05
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
Team 67 did something similar to this. They attached paddles on a chain and powered it to push the frisbees into the shooter at a constant interval.
As for 308 we used a pneumatic cylinder.
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
